Japanese Brain Test
Originally posted by: AlienCraft
Originally posted by: AmberClad
It also said my "brain age" is 20. I'm not sure if that's good or bad 😕...
Edit: I just re-read the OP. "This is a test on how old your brain thinks you are." So I'm apparently immature for my age? Great :roll:...
Reading comprehension....
Check #4....
4. At the end of game, the computer will tell you how old your brain is.
Topic Summary: How old does your brain think you are?
You are both wrong (and right).
MotionMan
I got 7 out of 10 on most of those, so I'm not sure what accounts for the spread. How long you took to click on the circles? How close to being correct you were?
Anyways, I'm not sure how much of a correlation there is between age and short term memory. Plus some people apparently have photographic memory anyway.
This is a test of short-term memory, I've never been that good at that 😛 I'm 22 and it says:
1st try: 51
2nd try: 39
3rd try: 35
Man, I sucked that round, but it was because my mouse is broken and I've got lag and my team is a bunch of n00bs and the terrorist are a bunch of wall-hacking, AWP whores, tossing flash bangs and spawn camping like a bunch of pussies...wait, what game are we playing???
Originally posted by: astroidea
Originally posted by: Praxis1452
Just quickly memorize the numbers across horizontally. It's easy to get a super low score if you try. For example say the numbers in your mind as you recognize them from left to right and repeat it while you select the numbers. These tests are always fail.
i can't even process them in my head horizontally when the numbers get to 7+ numbers.
can you do it?
It depends, but yeah if I'm concentrating. I've been up for a good 17 hours now so... tired but I got it once or twice. It really depends on the placement of the numbers. If they are placed vertically and far apart, no. But if close and near horizontal yes.
edit: I can get 7 reliably and 8 every so often.
after three games, my score went 37 -> 33 -> 27. it's a marvel that the brain can de-aged, and de-age so quickly!!!
