IWill SFF Dual opteron barebone system
Chaotic42
34,876
2,037
Originally posted by: n0cmonkey
Link.
Except for the fact it's using an nVidia chipset, it looks great so far.
I was just looking at this.
Seems pretty awesome. Too bad that memory and Opterons are so expensive. :(
n0cmonkey
42,936
Link.
If you think moderately, opterons aren't bad. Memory on the other hand...
And it probably doesn't have a 64bit PCI slot :|
Chaotic42
34,876
2,037
Well, if you're an IT department, they're not bad.
If you make $11/hr, they're way too expensive. ;)
mcveigh
6,457
I make $11.50.... this is right up my alley!
Chaotic42
34,876
2,037
Originally posted by: mcveighI make $11.50.... this is right up my alley!
Maybe someone who makes $12 will come in and buy us a couple of crates of 850s.
drag
8,708
Originally posted by: Evan Lieb
What's wrong with using an NVIDIA chipset?
Nvidia only provides closed source drivers for Linux. It makes it a pain-in-the-butt compared to when a company properly supports it. Plus closed sourced drivers are usually quite a bit buggier then Open Sourced ones and when using closed source stuff like that it makes it difficult to trace down bugs in the kernel in order to fix any problems that are happening.
Via stuff does pretty good for this sort of thing. I think that they provide decent documentation for their hardware so that developers can make drivers that work well with out serious trouble. Nvidia is obsessed with keeping everything a secret.
n0cmonkey
42,936
Nothing for most people. But their lack of documentation makes it a PITA to get it working properly with a Free operating system.
And that hardware firewall BS is hilarious!
Megatomic
20,127
In Windows XP the NForce chipsets are awesome. :)
I don't really like running linux on anything other than Intel chipsets, I've too many troubles with both NV and Via in the past.
biostud
19,953
7,049
So for a dual opteron setup that will sport a High performance Videocard they only need a 300W PSU.........
Jeff7181
18,368
11
LOL... that's what I was thinking...
n0cmonkey
42,936
There was speculation that it will require the low voltage opterons.
n0cmonkey
42,936
I think it said 1 or 2. Probably one. Which is several less than the number of drinks I've had tonight. Not that you can't tell by the horrible typing...
Sunner
It's all about serverworks. :D
And AMD.
Say that trying to run any IDE device using DMA on a CSB5 ;)
I definately prefer Intel.
n0cmonkey
42,936
And AMD.
IDE?
A CD-ROM for example? ;)
Ahhh, yeah I think I have one of those.
I'm actually running IDE on my serverworks machine. It's working quite nicely, although everytime I try to make a kernel it tries to leave the drivers out. :confused:
