r3pshow
Would it be possible to somehow 'balance' a big heatsink in contact with the de-lidded silicon? Kind of like how a GPU heatsink sits on top of the GPUs silicon without using a metal heat spreader in between the silicon and heatsink?
Like the head-on commercial, apply directly to the forehead silicon.
What did they do for SandyBridge? Was it solder or TIM?
Site claims changing the paste lowered the temps by 20c.
BS.
The problem with going block to bare die (without replacing IHS) is 1) the bare die without IHS is very flimsy, I shorted/fried a cpu/board running one in past. 2) You have to remove the socket, and also file/grind down area around the socket, otherwise fail to get adequate pressure. 3) even if you manage to do it, I wouldnt run 24/7, because again the bare die will be so flimsy will tend to bend, cause inadequate contact, short and fry.
Better to just use very low resistance tim and put IHS back on...wonder if could use indigo extreme between die and IHS.
