I have the GT on the side panel that's connected to directly to the motherboard (the third fan plug on the fan controller does not work
) and I just noticed it was producing a whine ... so while I was loosing the screws to find out what was going on, the whine disappeared (the fan was still on the side panel but the screw were loosened up to the max), so I guess the grill on the side panel was the cause ...
Oh well, I couldn't hear the whine when it was on minimum settings and I don't really need the side intake anyways, I just wanted to see if it produced noticeably more noise with it off (at minimum settings I didn't notice).
I don't hear any whine on the two front GT intakes when they are on max from the fan controller (to actually hear them to the point where it passes my own tolerance levels, I have to get down on all fours and open up the front door).
Since I wanted to test the sound for you, I tested the GT from the side panel just plugged into the motherboard with an open case, not screwed on anything just holding it in my hands, maximum setting for the fan in bios (can't disable it fan controls, sorry). All other fans were put to a minimum.
The Asrock AXTU utility says it's at 1800-1872 RPM and it's really quiet
. It does produce some sound but nothing too loud or annoying and pushes a good amount of air (not as much as the stock 212+ fan, but it's also much quieter at full speed). When it's standing up by itself on the floor, there is a soft whine, but when I pick it up it's gone. I don't think it's vibrations that are causing the whine when it's on the floor, maybe it's the intake from the (floor) side?
Oh and
here are a few photos of my cabling
guess I just wanted to get modular cabling and I saw a sale on newegg and just immediately wanted to purchase a new PSU, even if I didn't need one ... guess I'm just a gullible shopper (thank god I posted here before buying on impulse, thanks lehtv for saving me some cash
I won't get rid of the fans, I really wanted good quality fans and I liked testing them like this (and I liked the fans themselves)
... maybe I'll try it out with the AP. Spare fans never hurt anyone and I got like 5 desktops at home (that are used almost daily
) so if one of those needs a fan, I'll put one in it although it will be overkill for those PCs!
