Ivy Bridge 3770k testing checklist - help me to not forget anything
You would have to make a little platform, somewhere around the size of the CPU die, and affix sandpaper to it. It would be exactly the height off the surrounding table that the height of the inside of the IHS is. As you removed material, you would have to make it higher. Perhaps spring-load it.
Maybe take pane of glass, cut a hole in it, and spring-load a tiny block that has sandpaper on it from down below?
Hey what about sanding down the base of the lid a bit to reduce/eliminate the "gap" between it and the core of the CPU?
Both great ideas :thumbsup: I can't see myself making a spring-loaded contraption but I certainly can craft some kind of sand-paper coverd post that will fit into the IHS with enough room to slide back and forth.
Did you disable the onboard video? I know other members have had issues that seemed to be fixed by it. Might just be a temp thing that will be fixed with a later bios rev.
In the MIVE-Z bios there is an option to enable/disable the HD4000 (or HD3000 if Sandy). Not sure to what level it disables it but it does set the iGPU voltage to zero.
However, in my case it doesn't matter whether I enable or disable the iGPU, or install (not install) the virtu software...I've tested all the combos with both Sandy and IB and I get the same issue. It must be something borked with the mobo, I've got a ticket in with Asus so we'll see where it goes.
How is this coming?
Not well.
I RMA'ed my mive-z mobo thinking the problem I was having must have been the chipset.
Only the mobo checked out and came back as being just fine.
So now my 3770k is in the hands of the folks at Intel, RMA'ed.
Waiting to have the replacement shipped back to me.
It is/was such a strange issue too. I am glad I had my 2600k to use in the same setup as a debugging tool. If it weren't for that then I'd probably be pulling my hair out now.
If you sand the base of the IHS to get the under side of the IHS closer to the CPU die, will that lessen the clamping force of the CPU retension? Being new to Socket 1155, I didn't realize that the CPU socket retention mechanism clamps down on the IHS.
It clamps on the sides of the IHS. Parts that you aren't touching when you sand it.
You see in the following picture two tabs on either side that poke out just a bit on the IHS and the retention bracket clamps down on?
If you sand the bottom of the heatspreader you are decreasing the pressure the tabs will apply....But were most likely talking 1000ths of an inch so I doubt it would effect it.
How so? Don't get me wrong I'm not trying to argue your point but like...if you sand the inside and the top of the IHS is now closer to the core and thus your HSF is clamping onto something closer to the core (should be good right?), how does that affect the claimping pressure of the entire CPU in the bracket? From what I understand the IHS touches the CPU around the die so it's not just clamping right down on the die only. Does that make sense? What I mean is you're clamping the whole thing (green board and all) right down onto the pins so you're not really changing anything in that regard from my view of it.
If you think about what you stated you would realize that if you just sanded the inside top of the heatspreader the gap between it and the core would increase. If a person wanted to decrease the gap they would have to sand the base of the heatspreader. If you sand the base the tabs on the side would get thinner decreasing the pressure possibly. Most likely were talking very little material sanded off so I doubt it would make much differance on clamping pressure.
Ok that makes sense when you explain it like that. We'll have to see if there's any ill effects (if indeed this is done).
Well I think I'm done attempting to figure out the hardware incompatibility here and am just going to move on with attempting to do the tests.
After RMA'ing my MIVEZ mobo, my 3770k, and trying three different video cards, I have narrowed down the problem.
Only when I am using my 3770k, and only when I plug the video card into the native x16 PCIE slot, and only when windows is loaded and the video drivers are initialized, the screen is put to sleep and refuses to wake up until I reboot the system.
This issue doesn't happen with the 2600k plugged into the same system, and it doesn't happen if I put the video cards into any PCIE slot so long as it is not in slot 1 (unless I am using my 2600k, then the vid cards can go in slot 1 without a hitch).
/pullshairout
/pullshairout
Let the games begin 🙂
Video issue was with both nvidia and amd cards?
3 Nvidia cards. I have AMD cards in my other computers, but I did not pull them to see if the problem continued.
Given the fact that the problem only exists when I plug an IB CPU into the system, and it doesn't appear when I plug my SB CPU into the exact same system, tells me something is borked with either the BIOS or the OS chipset drivers.
This 3770k is amazing. My MIVEZ only allows the Vcc to go down to 0.8V (the BIOS does not allow it to be set any lower).
With my 2600k, it was LINX stable with 0.8V up to 1.8GHz. (with a NH-D14, and lapped)
But this 3770k is LINX stable with 0.8V all the way up to 3.1GHz with the stock cooler and stock TIM.
3 Nvidia cards. I have AMD cards in my other computers, but I did not pull them to see if the problem continued. Given the fact that the problem only exists when I plug an IB CPU into the system, and it doesn't appear when I plug my SB CPU into the exact same system, tells me something is borked with either the BIOS or the OS chipset drivers.
I'm not sure if I could have resisted the temptation to try an AMD card just to see what happened. Most likely nothing would change but one doesn't know till he tries at least.
Cool. What kinda temps you get at such low voltage and speed?
I'm thinking it'll take some heat to get the stock TIM under the heatspreader to set in good. Might wanna crank her up for a little bit to make sure it's set before you get too far into data collection phase for temps, etc.
At 3.1GHz and 0.801V (measured), I get 61C on my hottest core with an ambient of 25.1C.
At 3.9GHz and 1.098V (stock), I hit TJmax at 105C and start to throttle (and that was even with a slightly cooler ambient of 24.2C).
If the TIM under the IHS is going to reflow, it has already had its opportunity 😀 (I ran it at 105C and 3.9GHz for probably 3hrs)
Oh this is neat, I realized I was going about the low-voltage angle all wrong. Switched to using offset mode, my 3770k is currently purring along at 1.6GHz on LinX sipping a mere 0.632 V 😱
(temps are still hitting 47C though D🙂
I'd think that would take care of it.
Still using the stock cooler? Seems kinda high for such a low clock and vcore....But the stock cooler does suck!
Ok folks, I finally got my IB 3770k set up and functioning 🙂 . . . . . . . . .
WoW! I mean "Wow!" Talk about an enthusiastic thread!
My brain must have got stuck in molasses since last year. . . . After they released a "Gen 3" version of my P8Z68-V Pro, I thought I'd be SOL for being "IB compatible." Laziness! I should've been checking the ASUS web-site for the BIOS updates, and looking at the CPU List!
Must be all the "home theater" stuff I'd been doing . . . . which leads to "watching too much TV" . . . .
So you milking this experiment for all she's worth? Just wondering as no updates 🙂
LOL, I am but it is slow going for one reason - I just got back home after being away on vacation for nearly 3 weeks 😀 Ah the joys of summer 😉
Looking forward to knocking this out now. Almost done collecting my "stock" data before I start changing the TIM and the HSF. Then I've got lapping tests to do, then we get to delidding.
