Ok folks, I finally got my IB 3770k set up and functioning
It went less smooth than anticipated, lost a day trying to figure out why my MIVE-Z would not recognize/accept the latest bios build for the board (lesson learned - update every step of a bios, do not skip any bios builds when upgrading from an old bios to the latest bios) and then lost yet another day after that trying to debug why the system crapped out as soon as I installed Afterburner (which then became an issue with the Nvidia drivers, and ultimately came to realize I had to do a total clean fresh install because it was the Intel chipset drivers causing havoc on everything).
Anyways, that's all behind me now, so now I/we can get to the fun stuff.
Now I have every intention of eventually delidding this IB, and along the way I intend to do a complete analysis of the temperature/power/clockspeed profile for my 3770k as I did for my 2600k in this thread and this thread.
Hardware-wise we have the exact same hardware for the 3770k as I did for my 2600k. In fact when I was done testing my 2600k for the above threads I left the entire system in place, turned off and mothballed, in anticipation of re-using everything as a bonafide apples-to-apples comparison between IB and SB.
Now my concerns are that I will forget to test something and by the time I realize it then it will be too late. For example once I lap this chip there is no going back to testing "stock" conditions, etc.
Right now I have the chip installed with stock everything (stock tim, stock HSF, stock settings in the BIOS, etc). I have my intended test to perform but in the meantime if any of you folks want to chime in with any tests you want me to do then please chime in and I will attempt to oblige all of them (if they are reasonable, not testing salted versus unsalted butter as a TIM, apologies in advance
TIM's I have in-house at the moment are AS5, Ceramique, some older style TX-2 stuff, NT-H1 (my preferred, so easy to get repeatable mounts and cleanup is a breeze), and Indigo xtreme.
I know a number of you prefer MX4 and the IC diamond stuff but I don't have that here.I can be convinced to get some MX4 if it really is all that different than NT-H1. addendum: screw that, just saw it was $10 shipped from newegg, ordered.
For HSF's I have the stock Intel HSF, my lapped NH-D14, and my lapped H100.
So...before I pull this stock HSF off and remove its stock TIM...any requests for temperature/clockspeed/power tests? I'm going to do a baseline, obviously, just to keep apples-to-apples comparisons as we lap and eventually delid this sucker, but help me make sure we don't forget something at this early stage in the game.
