codeyf
Yep, she's no longer stock. 2 of the 6 mods I want to do are done. Only one left that won't void my warranty, which is painting it.
1. Stealth my CDRW drive - CHECK (didn't bother removing the face from my drive, just used the foam double-sided tape)
2. Pic a picture for the faceplate - CHECK (what biotch this was...note to self, get a new x-acto before making another)
3. Paint the case
4. Cut out hexagonal grill
5. Enlarge (slightly) all the side vent holes
6. Add top exhaust fan
Fresh from Googlegear......
wOOOOOt?!?!?!?!?!?!
The pic is kind of cheesy. Had I know how much of a BIOTCH it was going to be to cut it out using my old-azz X-Acto, i'd have looked more for a pic. One day, when I'm not bored, I'll prolly change it.
3. Paint the case
wOOOOOt?!?!?!?!?!?!
