Originally posted by: Confused
Well, i didn't unlock the L1 bridges, cos my motherboard has no multiplier adjustments.
But, i did connect the L3/4 bridges with a pencil, yes 🙂
If you're gonna try the L1, don't forget to put the glue/nail polish in the laser pits, on others it doesn't matter, only L1 does it matter 🙂
Confused
Congratulations on a very successful manual manipulation of Multiplier bridges...but take issue with your saying no need to fill/insulate the L3/L4/L10s since the sub-surface ground plane exposed in the open L1s must surely exist in the open L3/L4/L10s. You probably got away with it 'cause the graphite is not as likely to make contact with the sub-surface ground plane as a liquid conductive solution with its capillary action on surfaces. Also, you may have been closing some bridges which connect to pulldown signal resistors (which connect to gound), so accidental grounding of "those" bridges in the pits would not change the result, ie, a LO set by a closed bridge to ground is the same as a LO accidently set by connecting to ground in that bridge's pit. But suppose the bridge/s in question were being set HI...then any accidental LO set in the pit negates the HI you're trying to set by closing the HI bridge. Hope you understand what we're trying to point out.
Anyway congrats again...but good idea to fill the pits before closing.
John C.
