Humpy
- Mar 3, 2011
- 4,464
- 596
- 126
I'm going to try not to buy too many tools until I get more practice with my manual saw and my circular saw, which is what I actually got. I posted earlier that I got a table saw since I thought they were the same thing. I got a Makita Circular Saw. I also got a square and a chisel set. My working table supports a router, but I'm not getting a router yet.
A circular saw is essentially a small upside down table saw anyways. Using a straight edge or rip guide can get pretty much the same results too.
Get some quick grip or vise grip clamps to hold your work pieces so you can keep both hands on the saw while you're learning.
