itx motherboard in mATX case?
PCTC2
3,892
33
The ITX specification is based off of ATX specification. I have a mini ITX board in an ATX case right now. So it will work fine.
Zepper
18,998
Yup, at least the first four (sort of a square block) mounting holes starting from the upper left (viewed as in Pic 8 of the Egg's photo gallery of that case) should be to the same spec as mATX or ATX. So, as long as your mobo comes with an I/O shield to fit a standard case opening, all should be well. Extra support can be made from the old-school plastic standoffs.
.bh.
aigomorla
21,067
3,574
ummm i think any matx can hold a itx.
