It's arrived! eVGA 7900 GTO
Originally posted by: videopho
Nice...
but it's time to crank'er up to 5th gear....
I need recommendation on OCing tools for this card.
I don't know what ppl are using these days for nVidia cards.
plain old coolbits, you can go much farther with rivatuner....however not likely substanable beyond what coolbits would auto-overclock with these cards.
coolbits is the first thing come to mind. It's simple and easy to use.
Let run auto-detect first. Or shoot for 700/1600
Thanx for the link.
It does work with the newer nVidia drivers with the new control panel though right?
I can't wait to see these OC benchies. I have changed my newegg order from x1900xt to the 7900gto. I want to know if I need to change it back 🙂
I thought that Shimmering can be reduced by not enbaling HQ and disabling all 3 opts, but just disabling ani mipmap opt and putting texture clamp to clamp?
But cant wait to see some OCing results. 😀
685/1600 solid here, no issues except the 3700+ is a huge bottleneck in benches...
I need rivatuner, as coolbits stopped @ 800 mhz on the ram, maxed out the slider! 😛
21k in 3dMark03... WOOT!!!
Coolbits only allows up to 800 for memory max?
I haven't gotten that far yet, but that's as far as the slider goes.
Yep, on to rivatuner for our tweaking needs!
LOL we posted same thing & the same time 😀
Looks like i may need to try out Rivatuner if my card is stable to 800.
lol, that was pretty sweet 🙂
9200 in 3dMark05 for me @ 685/1600, that C2D is pretty awesome.
LOL, I got 24,000 in 3dMark01 SE 😛
I am also using the xtremeG 84.37 v2...
Good luck to you!
Hmm, what CPU do you have?
Oh, & did you run with HQ or just quality settings?
Originally posted by: GundamSonicZeroX
What's wrong with Powerstrip? 🙁
I dunno 😕
The only nVidia cards i've ever owned before...well, that i kept anyway...were 6800GTs.
So i don't really know much about OCing them.
So there's:
Coolbits
Rivatuner
Powerstrip
What else do you guys recommend?
And if someone has links to the newest Rivatuner & Powerstrip, please post away.
Sorry, I forgot I am running my GF's 4200 x2 right now 😱
I am going to use rivatuner, I have used that in the past. I haven't used power strip since oc'ing my 8500 way back in the day!
I was using Q settings as well. I am severely CPU limited with a 2.2 ghz x2, evidently.
*ATI Tool cause my computer to reboot in a loop, so I am no longer using that...
You can try ATITool beta. If it recognizes 7900 GTO, it should be the most flexible to use and the easiest to set up.
http://www.techpowerup.com/downloads/341
After a new card comes out, the guy who writes it has to update the tool. Who knows? It may recognize these cards as 7900 GTX.
Edit:
My link was incorrectly made to version 14. Version 15 should be used.
I updated the OP with some prelimary overclocked results.
Stability is still questionable.
http://www.techpowerup.com/downloads/259
I used ATiTool with my X1900XT, & TBH, i'm kinda hesitant to use it, since i had horrible results with my X1900XT.
But then again, i couldn't OC my X1900XT with any programs w/o instability, so i can't really blame ATiTool entirely i guess.
