S SludgeFactory Platinum Member Sep 14, 2001 2,969 2 81 Jan 7, 2010 #26 That phrase and its cousin "at the end of the day" can both go DIAF.
IronWing No Lifer Jul 20, 2001 72,959 34,139 136 Jan 7, 2010 #27 The fact of the matter is that the reality of the situation is that it is indeed what it is.
meltdown75 Lifer Nov 17, 2004 37,548 7 81 Jan 7, 2010 #29 good sports radio show in Detroit...... "Shawn Belligian... he's the reason" IT IS WHAT IT IS
N nageov3t Lifer Feb 18, 2004 42,808 83 91 Jan 7, 2010 #30 Kadarin said: It's a moo point. Click to expand... fixed
JulesMaximus No Lifer Jul 3, 2003 74,585 985 126 Jan 7, 2010 #36 Of course it is...if it isn't, well then, it isn't right?
rh71 No Lifer Aug 28, 2001 52,844 1,049 126 Jan 7, 2010 #37 BoomerD said: Be that as it may.... Click to expand... D:
arrfep Platinum Member Sep 7, 2006 2,314 16 81 Jan 7, 2010 #40 The purpose of this sentence is to inform you of the purpose of this sentence.
AbAbber2k Diamond Member Mar 1, 2005 6,474 1 0 Jan 7, 2010 #42 darkxshade said: But is it? :\ Click to expand... It is.
IronWing No Lifer Jul 20, 2001 72,959 34,139 136 Jan 7, 2010 #43 What I am is what I am Put what you are away What I am is what I am Put what you are away What I am is what I am Put what you are, oh what you are
R Ronstang Lifer Jul 8, 2000 12,493 18 81 Jan 7, 2010 #44 That depends on what your definition of "is" is.
SlitheryDee Lifer Feb 2, 2005 17,252 19 81 Jan 8, 2010 #45 Ronstang said: That depends on what your definition of "is" is. Click to expand... is is is
AbAbber2k Diamond Member Mar 1, 2005 6,474 1 0 Jan 8, 2010 #46 Ronstang said: That depends on what your definition of "is" is. Click to expand... SlitheryDee said: is is is Click to expand... *head asplode*
StrangerGuy Diamond Member May 9, 2004 8,443 124 106 Jan 8, 2010 #47 SlitheryDee said: is is is Click to expand... Is is is is it?
P Parasitic Diamond Member Aug 17, 2002 4,000 2 0 Jan 8, 2010 #48 Because I am whatever you say I am?
D darkxshade Lifer Mar 31, 2001 13,749 6 81 Jan 8, 2010 #50 AbAbber2k said: It is. Click to expand... But what it is ain't exactly clear!
