<< hey look, im sorry, its not like im looking to host the code red virus. i run security programs and keep with all the updates. thats why im going to install linux and hopefully that will stop all that. >>
No you aren't looking to be a cracked computer but you are providing the opportunity by not EDUCATING yourself BEFORE you set this stuff up. In all honesty if you can't secure a windows machine you have ZERO chance securing a modern linux distribution. Mandrake is especially bad because it installs so much crap on default runs. I suggest you head on over to Security Focus and read every article on the site before you attempt to administer an open network server again. Learn your lesson from this, if you can't administer and install the OS in a secure manner you should not run server services.
No one is infallible, except Russ. I was rooted in the first year I had linux up. I found out only on sheer luck because the script kiddie was so lame that he left the log entries in tact. After that I went through numerous HOWTO's and documents on securing a distribution and I run a pretty tight ship these days. In fact I consider my only weakness that I run BIND without chroot.
Learn from your mistake, don't repeat it.
[edit]Security Focus seems to have changed(in what appears to be an attempt to make money) from when I last visited, it's not as usefull anymore. Others should be able to suggest security orriented online resources for whatever OS you pursue.[/edit]
