This is a follow up from this thread. If you can help with the problem in the original thread, that would be great too!
HELLO everyone!
It's a new week and I have new problems. This time I have brought pictures.
Problem 1: Hard Drive doesn't fit into the metal box
There is 2 metal boxes on the bottom of the case where you are supposed to put the hard drive/s. The problem is that the hard drive doesn't fit into the metal box. The metal box has two little metal picks inside of it that are supposed to hold the drive in place, but ultimately get in the way of putting it in there. There are holes where you are supposed to screw the hard drive into it, but you can never match up the holes thanks to the metal picks. And when you can actually find a way to put the hard drive in the metal box (not matching up the holes), there is a metal lip on the inside of it that keeps it from totally going into it. I have no idea what to do. Could it be the hard drive? The hard drive is different as it doesn't take the normal hard drive cord to hook it up (SATA maybe) but takes a much smaller plug.
Pictures:
http://img518.imageshack.us/im.../3969/computer6eu3.jpg
Problem 2: DVD drive can't be held in place
The place where you put the cd/dvd drives at the top of the case is weird. Instead of places where to screw in the drive, there is a black plastic piece that somehow locks and unlocks the drives. I have not found out how it works, and have played with it for hours with no success.
Pictures:
http://img69.imageshack.us/img69/7074/computer4yk6.jpg
Problem 3: Fan Power Cord
I have a fan mounted to the back of the case. It has a cord coming out of it that looks like it would go into a white slot on the motherboard, but I am not 100% it goes in there since I have other items that look like they might also go into the place. The power supply also has cords that look like it could hook up to the fan, so I am really confused.
Pictures:
http://img225.imageshack.us/im.../2689/computer7el8.jpg
More Coming Soon!
HELLO everyone!
Pictures:
Pictures:
Pictures:
More Coming Soon!
