Issues with GA-7N400 Pro
cuban88
I udpated my MoBo to the GA-7N400 Pro and have had some problems.
I installed the OS 3 different times, updated the BIOS, Downloaded all the latest drivers from Gigabyte.
I had Samsung 3200 Memory, Saphire 9700 Pro Video Card & Audigy 2 Sound Card.
On the first OS installed, I tried running Easy Tune, both installed off the CD and downloaded and it would run but I didn't have the buttons in the middle that allow me to go from Easy mode to Expert....so I couldn't do any adjusting of clock speeds.
On the second OS install, it won't run at all.... it loads into the system tray but gives me an error every time I try and run it. I then re-installed all drivers with the latest from Gigabyte. No luck.
I found this odd because I am doing a fresh install with the same OS on my GA-7VAXP and it all works like a charm.
I am now going to re-install the OS but put the same video card & memory in that I had in the 7VAXP.
Any ideas?
By the way, one other odd thing is that the Lan card won't even be recognized until you install the board drivers, even though it's set to "Auto" in the CMOS. Maybe it's just to new for windows to recognize.
Thanks for any help... I'm on my last string of sanity.:|
Any word on this? I'm thinking about getting this board or the ASUS A7N8X Deluxe. Per Anandtech's report, sounds like the Gigabyte board is better, but sounds like alot of problems too.
I have had the same problem with my EasyTune4. I do not have the advanced mode nor the easy mode settings to choose from. As it stands right now...the program does nothing. It's just a hardware monitor at this point. I can't make any adjustments even with expert settings in the bios.
Also I have ahd lackluster performance with benchmarking programs (read: 3dmark) I got better scores with my old epox 8k7a+ and a 1.33 athlon with all the same drivers and hardware (sans motherboard obviously). I wonder if there a problem or setting that I am aware of. So far I have not been impressed with this board like I had hoped I would have been.
I have the same exact issue....I attempted to download version 3, but no such luck...cannot even DL version 4 off the web site right now.
