Issue with SBS 2003 & clients on different subnets
Originally posted by: Kaido
Originally posted by: spidey07
I think it's a lost cause. He won't listen.
But posting the exact results of those tests would point the compass in the right direction.
I just haven't had a chance to yet - I'm testing the VPN connection from home using the VPN router, and everytime I switch between it and my wireless router, I get a new IP address since I'm using cable with a dynamic IP from my ISP. Even using the VPN client software to get in, I can't change the IP address due to the way the webpage is setup over a remote connection. I have to wait for someone to get into work to change it for me. End result, I have to wait until tomorrow for someone to hook up the connection for me. Be patient 🙂
What IP are you trying to change?
Originally posted by: kevnich2
I agree with spidey on this one, it definately sounds like a DNS resolution issue.
Results of nslookup:
*** Can't find server name for address 192.168.253.2: Non-existent domain
*** Default servers are not available
Default Server: UnKnown
Address: 192.168.253.2
So it's not seeing the DNS setup. Our VPN is configured properly; we can ping the server @ 192.168.253.2 from the 192.168.11.x subnet. Do we need to add the 11.x subnet to the DNS listing somehow? Edit: I can also ping SERVER.mycompany.local...
Also, does anyone know how to enable users to disable the Windows firewall on a domain? I cannot disable the Windows firewall on networked workstations, even after editing the group policy on the server.
Basically you punch in the remote IP of the router you're trying to connect on the local router; that's how it knows where to point the tunnel to (along with some other security-related info). I have a wireless router that I use for my family's network at home, but I have to unplug the modem and plug it back in to get it to work with the VPN router I am testing here. Everytime I do that it gives me a new IP, which means that it has to be updated on the remote router. Edit: Changed a setting on the router to allow for remote administration; that solved the hanging problem when I'd go into the Advanced button on my VPN connection, so now I can change all the features I want myself. Whoohoo! 😀
this is DNS related. You cannot talk to your SBS server via DNS. That is required. It's time to start checking firewalls and stuff, and if you can't find a quick easy problem to fix, it's time to break out the old school hub and Wireshark.
Yeah, it's strange - as long as you're on the same subnet as the server (192.168.253.x), you can access the DNS. Otherwise for all intents and purposes it doesn't exist 😛
Quick update - got things partially working. 4 firewalls and several router settings later I can somehow browse the domain. Using nslookup, I cannot "see" the domain - I can ping the IP, I can ping SERVER, I can ping SERVER.mycompany.local, but I cannot ping mycompany.local. nslookup still gives me the same thing, non-existant domain. However, I can browse the domain over the VPN, print to printers, see shared folders on the domain, and I even show up on the domain. We've played with firewalls, vpn, rras, the routing table, etc., done everything by the book, nada. So somehow I can access what I need to without actually seeing the domain. Awesome! 😀
check DNS, you may not have a record for mycompany.local as a valid name (no A Name record)
if you can ping myserver.mycomany.local you are good.
I'll check when I go into today...we can ping mycompany.local from inside the network but not via VPN. I'm just happy that it works, so thanks for your help everybody! 🙂
