Why would anyone overclock on an MSI board anyway? They have a horrible failure rate.
This is ridiculous! Shame on MSI, and Intel too!
I want my mobo to cost no more than $40 despite having a BoM of $300...and I demand it to be so over-engineered that I am virtually guaranteed (not that I'm willing to pay for said guarantee) to be able to overclock my CPU to 7GHz.
Not only that, but when I do overclock my $60 CPU to 7GHz I expect the CPU manufacturer to send me a rebate check to cover the elevated electricity costs. After all it is my right to get absolutely everything I want, even if I don't pay for it, simply because I'm 'merican and its my gawd dern given right to do what's I like, whens I like, hows I like.
Freedom!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I like my board, but it is a bit higher end then that one.
Why is there not a single Asus motherboard on that list? I know they aint that good...
VRM Over-Current Protection
Warning: Spoiler! (Click to hide)
Over Current Protection (OCP) is something I have recently been examining. Protection features exist against VRM overheating/overloading depending on motherboard model and brand. I believe it is a crucial feature on motherboards today, because this is the function that will protect your VRMs from a catastrophic failure. This is why I have never seen ASUS boards fail even if people take a lowly 3+1 ASUS boards and try to overclock a Phenom II x6 on it; ASUS boards feature this technology, as it is a part of the PWM controller design.
We ALL want that $100 mb that OCs as good or better than the $200 plus mb so we can brag about how smart we are etc. In my humble opinion that rarely works out.
The reponse fro the MSI engineer was justified and frankly correct. Belly aching about it is a classic " I want something for nothing argument".
Lines such as " wanting champagne on a beer budget" or "wanting a Cadillac for a Chevy" price most likely apply. I don't blame the mb owner for asking MSI for help. Just don't go ballistic when you get such a reponse about overclocking.
I still buy most computer components from Newegg. However, I place less and less faith in the reviews, especially where the poster fails to list all of the other components. The actual review that complains about the OC problems does not list the memory,psu etc. used when the mb limit was 40x.
In my experience that's exactly how things work out these days though.
I've probably used 100-110 Asrock Z68, Z77 and Z87 boards in the past year. Every single one of them was capable of running 2500K, 2600K, 2700K, 3570K, and 3770K chips at 4.4Ghz or better. And not one of those boards was more than $110 at MC, most of the time I was able to get them for $99 or less.
I got an ASUS M5A97 and Phenom II X6 1045t for $145 @ Micro Center, which easily runs @ 3.7GHz (40% OC). I also bought an open-box M5A97 which easily runs an FX-4100 @ 4.4GHz (22% OC). There are cheap motherboards made for overclocking, and then there are cheap motherboards that allow overclocking.
Because they're that good. And this is why you don't use a 100$ cheese motherboard when you're going all-out with LN2/water cooled overclocking.....
Do you hear of a lot of Pro/Deluxe failures related to OCing? Maximus? No? There's a reason. Better components and higher quality.
The Haswell voltage regulator still needs to be provided a voltage and current.. 1.8V by default, often increased to 1.9 - 2.1V by overclockers. You really didn't think those tiny surface-mount components next to the Haswell die could replace the large capacitors and MOSFETs with their own heatsinks that you find around the CPU socket, did you?
