Is this heatsink going to rock or stink like other thermaltake products
Scabilian
677
it looks pretty sweet but that doesnt mean jack crap. could be some nice eye candy for my GTS ;)
Adrian1
Banned
Apr 11, 2001
138
that is what i was thinking gts or ultra...hey kev dont pull your current hsf off you gts ....dont want to have to send another one in for you hahahah...by the way you can have this hub if you want it back just let me know when i will get a switch instead...that would be better for lan parties anywayzzz...when I come down
Mikewarrior2
7,132
Couple of major potential problems:
The fan assembly being separate, its metal "ring" doesn't look like it will transfer heat from the base well at all.
the copper section, if like the copper orb, will be manufactured separately from the blue portion, then soldered together. In the copper-orb's i have seen/tested, there are times when a good portion of the copper-aluminum region that is not connected. Poor manufacturing quality is drastically detrimental to this heatsinks performance unless they changed manufacturing quality/procedures.
If made well, could be a decent cooler. As it stands, will probably be a nice pretty one that will sell plenty on the merits of looks alone.
Mike
