is thermal paste required?
MrHappyMonkey
3,091
I am transfering a P3 700 w/ stock HS/F to another mobo and I noted that it originaly had thermal paste between the CPU and HS/F. I don't have any thermal paste with me right now. Will it be ok to just place the HS/F over the CPU w/o thermal paste? I'll be running this stock w/o over clocking hence the OEM HS/F.
John
Moderator Emeritus<br>Elite Member
4
IMHO, no. Wait until tomorrow till you can pick some up locally at any Rat Shack, Worst Buy, Crap USA, mom-n-pop shop.
Boonesmi
14,448
you really should use some kind of thermal compound
but... there have been several times ive used a hsf with no thermal paste for short periods of time :) just make sure the temps dont get to high
jdogg707
6,098
Use some kind of thermal paste or grease, anything is better than nothing almost...because even at default settings it's gonna get a little warm...
brunswickite
6,386
dont forget to try your local Circuit Sh*tty or Office Cheapo
Zim Hosein
Super Moderator | Elite Member
65,331
404
MrHappyMonkey, IMHO, wait till you can get some thermal grease or at least a thermal pad, they are between the HS and fan for a reason. I wouldn't want to see you fry your CPU because you were impatient, hope this helps :)
Or even you local Staples as they have Antec Thermal Paste.
Legendary
7,019
Staples...staples...scraples? nah...sh!tples? no rhyme...someone help...?!
amdskip
22,530
13
Don't think office max has anything, at least the ones around here don't. Tubes range from $3-10 I'm guessing.
