Originally posted by: Mark R
Originally posted by: Eli
Yeah, I realize that.. What about when you don't really care about space and such, though?
I mean, the space savings with one unit vs. two would be nice, but the main advantage in my eyes is throwing clothes in and getting clean, dry clothes out without having to do anything.
I will wait for a model that is comparable to standalone units, I guess.
Apart from the fact that the drying takes a bit longer than a conventional vented unit, there really isn't much difference.
The washing component is the same as a conventional washer - because it is a conventional front-loading washer.
Drying is a bit slower due to having a built in condenser. But it's a lot more convenient than a conventional vented/unvented dryer because the unit is self cleaning - no lint filters to unblock - because the washing part of the machine washes it. No condensation to drain like in a conventional unvented dryer - it's got a drain built in.
Cost is about the same as a conventional washer - maybe marginally more than a basic washer. Definitely way less than separate units.
Energy consumption is pretty similar to separate units. Someone mentioned cold fill earlier in the thread - all washer/dryers are cold fill that's true. But all new European washers are cold fill too. It's actually more efficient to do it this way - because conventional front loader hot fill machines end up drawing a large proportion of their hot water from idle pipes, in effect wasting the energy that went into heating it.
Water consumption is a bit higher than separate units because the dryer component needs cold water to run its condenser.
