if I count all the fans on my comp including cpu and chipset fans as well as case fans. I have 12 but they are all ball bearing and dont make that much noise.
the cpu fan is a Thermaltack spark 7+ , ~1300rpm to ~6000 which is hooked to a controller it seems to be the noisiest if i turn it up all the way.
There is two small fans, one on my memory, and one on my 865PE chipset. - noise minimal
There are 2 - 80mm on the Enermax 420watt PS ( like most people)
There are 2 - 80mm in the front of the case with the harddrives behind them
There's one (1) 120mm clear w/ blue LEDs on the window in the side blowing on mobo
There are 2 - 80mm on the back of the case below the PS
There is one (1) 80mm Tricolor led fan in top window (yes i have windows on all 3 sides)
and last but not least the chipset fan on my 3D card which is quiet as well.
most of the 80mm fans run about ~2700rpm and can not be adjusted, the only other fan i have that i adjust is the 120mm on the side it seems to be a little noisy when turned all the way up.
i would like to now what other people have setup? and what they think?
