Is There Such a Thing as a Non-Stick Egg Pan?
OverVolt
14,278
89
One that does not have cancer causing coating on it? I'm not sure. I do have a non stick that works great for eggs though. I paid a lot for it in hopes that it will be a high enough quality that it won't shed it's coating. So far so good.
I have a cast iron but I find it's a pain to clean, I can never really get it 100% clean. You're not really suppose to use water or abrasives to clean those. With the non stick it cleans well because it's well, non stick, so I just run it under the sink and then use dish soap and paper towel and done. If I'm feeling lazy I put it in dishwasher, but I try to avoid it as I don't think you're really suppose to put non stick pans in dishwasher even if it says you can.
Cast Iron.
Eggs don't stick to my cast iron and I even wash it with dish soap since it has a bazillion layers of seasoning, which is really just stuck on oils. I cook with plenty of ALA'a and butter both of which polymerize very well. Has a nice black patina that withstands soap even.
I started really scrubbing it when I noticed black flecks in my food which after some searching I came to the conclusion was really just dirt. Cleaning it really well reduces the black flecks.
Fritzo
41,920
2,161
I'll still stick to just whipping mine out while hot, but your an old friend (relatively, I've only been around a couple years) also I'll beg to differ with a bit :)
That's enough cast iron pan talk for me, youks and away !!!!
It works :) I never have to wash my pans, and they keep their seasoning.
Imp
18,828
184
I use soap on my cast irons and rub them down with a cellulose sponge. They haven't rusted yet. One's 5 years old and was soaped and yellow-sponged the entire time. Seasoning on that thing is great. I wipe dry-ish, air dry, and oil before storage.
It's too big a hassle though. I'm sticking to stainless in the future -- zero work versus slightly more work.
Mike64
2,108
101
God damn it... why has this become so commonplace in our dialect as of lately? It's really worse than the their/they're/there issue because people are actually using this phrase in their speech patterns.
*sigh*
I'm generally among the first to object to flat out "incorrect" grammatical usage (things like using "he and I" as the object of a verb, versus vernacular contractions, etc), but in this case, what's so awful about what is basically a shortening of the phrase "I have just seen"?
And if we're going to get all persnickety about speech patterns in casual conversations, I'd have to point out that the phrase is "as of late", not "as of lately.":D The former is of course is basically a synonym for the adverb "lately", but grammatically, "as of lately" is, just, well, wrong. ;)
Mike64
2,108
101
The grease isn't in the pan anymore. It goes somewhere.
A half tablespoon of oil (60 calories) is a small thing, but relative to what you're cooking in it (150 calories worth of egg), it pretty significant. Especially if somebody is tracking all those individually insignificant things in an effort to not be a fatass.
Nobody gets "fat" from an extra 60 calories here and there. They get fat from eating, in addition to probably more quite a lot more "real food" than they need in a day, the 1000 or calories of snack food and/or beer they consume without batting an eyelash or giving it a first let alone second thought while parked in front of the TV ...
Carson Dyle
8,173
524
Because it's not. It's used incorrectly for "saw".
This is nothing new, though. Where I grew up, many of the poor and uneducated people of the area used that same phrasing. When I see it written, I can actually hear the accent and see the greasy hair and decayed teeth.
"I seen them damned Johnson kids down by the creek again. They was throwin' rocks at the ducks."
13,920
Cast Iron.
Cast iron does not really seem like something that would be very non stick due to the rougher surface. Kinda like trying to clean something off concrete vs off a flat plastic surface. I have yet to figure out the proper way to even clean that, I just have a build up of grease and crud on mine. I can wet a paper towel and rub it and it will come black each time. (don't really want to ruin dish cloths so always use paper towels) I use it only for meat where having a build up may add taste, kinda like a BBQ.
Howard
47,982
11
Better cast iron pans actually have smooth surfaces, and a well-maintained seasoning is quite smooth, not rough or flaky.
Imp
18,828
184
Ya, I'd pay up to an extra $50 if Lodge would just bother to sand their pans down. They are crazy cheap right now at just $20 to $40 for a skillet -- I'm willing to spend $150 on an All-Clad.
Staub has sanded down interiors, I think, but they use some enamel or paint on the outside, so no thank you.
Fritzo
41,920
2,161
I'm using a Lodge right now and it's fine. You needs to use it with some high heat cooking to get it ready for use. Sear a few steaks and pork chops in it and you're golden. My only complaint is the handle it too short. I got one of those handle covers for it but you have to keep it off until you use it because it gets too close to the burner.
destrekor
28,799
359
I am right with you there. I so want to buy a brand new sanded-smooth cast iron pan.
ControlD
5,440
44
Do you clean yours when you get done cooking with it or do you just wipe the pan off and put it away?
I started cooking with cast iron a couple of months ago and I have a hard time not cleaning the pan with a little soap and water like I always did with my stainless or non-stick pans. It just doesn't seem sanitary to cook meat in a pan and not soap it up after. I do enjoy cooking with cast iron so far though. It cooks food differently than my old teflon stuff for sure.
destrekor
28,799
359
You can get great results with modern pans, but they will never match what you could achieve with the older, smooth pans. You may get close, but never achieve the same level of non-stick.
That said, I've been meaning to strip my current Caphelon pan and try out the flaxseed seasoning method. And I want to try cooking with higher smoke-point oils as well when searing.
slag
10,473
Are you crazy? There is nothing wrong with butter.
Assuming you don't eat a stick of it every day and engage in physical activity beyond laying in a bed and washing yourself with a stick, butter is a perfectly healthy part of your diet, like anything else that is naturally-produced.
Key to anything: be smart about what you eat and avoid fake processed bullshit.
Bull. Butter is good for you. Eat a stick a day to coat your blood vessels so the blood flows faster. It's common knowledge.
olds
50,127
781
I do put a little oil in the pan and the eggs don't stick to the bottom. They stick to the sides where there is no oil. Now I can't flip them. I have to use a spatula and end up breaking a yolk.
zinfamous
111,913
31,439
The wife has gotten to be pretty much expert in the Chef Ramsey method of scrambled eggs, I actually prefer those now.
low-to-no heat. butter. scramble in the pan. low heat. scramble. water. butter. low heat, scramble. butter. butter. water. butter. scramble. no heat. scramble. butter.
salt.
zinfamous
111,913
31,439
It helps the football-sized orb of red meat slide straight through the 'ol impacted colon.
:thumbsup:
zinfamous
111,913
31,439
standard way to scramble, omelette, or go various forms of fried or over-easy is to always use a small pan. ~8" pan is generally called an "egg pan" for a reason.
coat the pan surface, including the sides and especially the bolt-ends that attach the handle to the inside of pan, with one thin layer of butter. I just rub the stick across the warm surface quickly to give a nice thin layer. As long as you cover all surfaces, this is never a problem.
Fritzo
41,920
2,161
When done, I turn the pan to high heat so it starts to smoke. Then I add enough water to cover the bottom of the pan until most of it boils away. Take it off the heat at that point and wipe it off. It'll be completely clean if you do that.
slag
10,473
I cook my eggs all on high heat to get a nice layer that doesn't stick. Then I turn the heat off and finish cooking with the residual heat from the cast iron pan. Takes mere seconds to cook an egg that way and it doesn't stick or burn. I use a cheap cooking spray which is basically just olive oil in a spray form.
Fritzo
41,920
2,161
Grapeseed and peanut are excellent to start with (I like them both for steak). Safflower and avocado are up there as well but they're expensive.
gotsmack
5,768
I eat 5 scrambled eggs a day for dinner and have never had a sticking problem. I use a $20 ceramic pan (11" and no rivets) from Homegoods.
Medium-low fire and a tablespoon of butter. Addin the butter after the pan gets hot, swirl around the butter to coat the bottom then add in the egg and stir vigorously.
OverVolt
14,278
89
Lol after a minute I can swirl them around the pan or just leave them to cook sitting still the whole time, doesn't matter ;)
Initially eggs did indeed stick. Its just a lodge, rough surface cast iron skillet. Mostly used for eggs, boca burgers, mushrooms, and perogies in that order :p.
Smart balance vegetable oil and land-o-lakes butter makes a fine seasoning. Since I'm sick of the canola in smart balance I'm moving on to corn oil/soybean oil soon. We'll see how it goes.
Olive oil isn't that great in cast iron.
But yeah egg bagels & sandwiches out of a cast iron skillet is like one of my staple foods. It takes 3-4 minutes to make an egg sandwhich. In the winter you even get to warm up by the oven.
