R rnmcd Platinum Member May 2, 2000 2,507 0 0 Jul 3, 2000 #1 I am in the process of buying a new 3.5" floppy drive and was wondering if there is much of a difference between the brands? Is TEAC or HI-VAL good enough? The TEAC comes WITHOUT the ctrl mount. What is the ctrl mount? Thanks,Rnmcd
A AMB Platinum Member Feb 4, 2000 2,587 0 0 Jul 3, 2000 #2 I do not this you will need the ctrl mount whatever it is. I do not think it is worth worrying over the makes of FDD, how often are you planning to use it anyway. I have a Teac FDD and it has lasted for about 4 years without and problems.
H Henry Kuo Platinum Member Mar 3, 2000 2,248 0 0 Jul 3, 2000 #3 i never care about their brand since i think they are all the same...
4 4824guy Diamond Member Oct 9, 1999 3,102 0 0 Jul 4, 2000 #4 I have benchmarked about 5 floppy drives by different companies recently, not much performance difference was shown. I wouldn't get worried about floppy performance.
M Mday Lifer Oct 14, 1999 18,647 1 81 Jul 4, 2000 #5 if you want, you can get a superdisk, you know that 120MB deal. the drives handle 1.44 floppies faster...
