Is there any need to OC my CPU further for gaming?
Deders
2,401
is no one going to ask "How much RAM?" lol, assuming you have 8 gigs (it does make a difference in gameplay from 4 gigs)
Interesting, I can't say I noticed much difference but I didn't have much time to test as I had to send them back after they started causing BSOD's.
Which games are we talking about and how much of a difference?
aigomorla
21,042
3,522
post 4ghz will u see a difference?
no...
i dont think the ends would merit you going beyond 4ghz... well not unless ur gpu was a 7970 and u crossfired.
Then yes... ud probably be able to get somewhere near 3-10 more fps if u went up past 4.5
However again... 7970.. which u dont have... so... no.. id keep it at 4ghz and be happy..
driedupfish
35
So you are saying my current GPU (7950) isn't powerful enough for my i5-3570k to go beyond the 4 Ghz? What if I superclocked my 7950? Would 4 Ghz still be enough then?
hackerballs
138
Tons of power for both card and cpu @ 4ghz.
Should be able to play Ultra with good fps. And increasing RAM from 4g to 8g will make a difference in gameplay. Try it, Ram is cheap today.
I would not Superclock the 7950, but a moderate OC should be fine as this is a good card
Face2Face
4,100
215
Ran a couple benchmarks with three AAA titles to see how much an overclock would help you. This was with an overclocked 7950 in a single gpu configuration. As you can see below, Crysis 3 is the only title to gain a real benefit from overclocking. Even @ 4.0Ghz you are fine....
Crysis 3 - VHQ- Textures - HQ - System Spec - SMAA2X
Tomb Raider - Ultimate Preset
Farcry 3 - Ultra Settings - SSAO - MSAA2X
Slomo4shO
586
I've been playing Supreme Commander lately and that game pegs Core 0 at 100% and all other cores are basically idle. That means that at 3.4 GHz (stock), my CPU is a huge bottleneck.
Wouldn't the game engine be the bottle neck since you are only using 1/4 of your CPU capacity...
Udgnim
3,680
124
think an OC can help if you're running multi video card
not sure if it happens often with dual, but if using triple or quad, I believe CPU limitation can occur
unfortunately I can't find the article / review that tested it
found a simple example from 2010 that only covers dual card
http://www.tomshardware.com/reviews/amd-crossfire-nvidia-sli-multi-gpu,2678-8.html
not finding an example showing scaling for 3 or more GPUs
