IS there any happy A8N-SLI owner?
Just to put in my own comment, but not to thread crap:
I am NOT a happy owner. I only say this for an idea of issues that might crop up, but I dont want to make a new thread that looks like i'm asking everyone for help.
I started to get a bad feeling when putting on the a64 requires an inordinately large amount of torque to rotate the arm that locks the HSF down. But when I did the first boot everything was okay. After I got all my drives hooked up I decided to go ahead and give it a boot. I had to spend some time trying to fix Inaccessible Boot Device errors from XP because I decided to transfer the old installation over to this all-new computer. Once that was eventually overcome, I ran into a new issue - after some time I start having an issue where the video signal will just drop out. I dont know if the computer stops in whole or not, but the restart and power switches don't work at that point. It did stay on long enough once to all the new parts configured, then the video went blank. Another few times XP would stay up for maybe 20 minutes max and I was able to run the Source stress test that comes with CS: Source at 1280x1024 and got 80 FPS average, which I was pleased with. Eventually the video outs became far more frequent and the computer developed a habit of also rebooting. At this point I tried clearing the CMOS, following the instructions with the manual just to make sure I did it right, and after that, the board wont boot at all. It gets power and when the switch is hit all the fans will power on, including the video card fan, but no boot codes at all, it just will sit there. I have now at least gotten it to the point where it will reliably boot, though at least 50% of the time no video signal comes.
I'm at an impasse for what could be the problem, but I highly suspect, due to the variable nature of the issues i'm having, that it is the A8N-SLI. Granted the times it will stay up the longest are after it has been sitting cold for awhile, which lends itself to a heat issue, a fact which is also supported by the fact that the a64 HSF doesn't get very warm and the HSF on the video card hasn't yet seemed to get warmer than ambient. It is one of the 6600GT's that have an axis of rotation that I accidentally disturbed, but thermal contact seems decent, but not very good. I'm almost positive it's not the RAM because it went through about 75% of a memtest86+ with no errors (ended early because the video blanked out and system rebooted). It's not a power issue because i'm down to running nothing but the bare minimum and an optical drive with a bootable linux distro. It's probably not CPU because I think the errors would be accompanied more often by a reboot then instead of a hang.
So, sorry, a short post turned into a long one, but in my experience I think there's pretty big problems with at least my A8N-SLI - I've accepted this is an RMA board - though every batch will have a defective product, but at least it seems like more people in this thread are alot luckier. 🙂
You can add me to the happy list, just got my new system up and running today. Booted it up and everything worked PERFECTLY. That was a great sigh of relief for me because I've been seeing all of the bad posts. Didn't have one problem at all putting it together. Very easy installation for everything and was done in no time. Only problem is I have to find another 6800 Ultra PCI-E for SLI mode, but no problems at all with the motherboard. After all... it is ASUS.
Ainaas, I seem the have the same issue as you. My board was running great for one day, I was very happy, everything appeared fast and stable, it went together easily, and I didn't have any issues. Then, the video went out. Now, when I try to boot, the fans spin up, but no video, and no boot codes. Bios reset, removed all cards, switched to plain pci video and it still just sits there.
So I'm waiting for an RMA too. I was happy for a day, and I look forward to getting a working board back (hopefully a later revison board). It reminds me of my upgrade to an Athlon 500 on an early FIC mobo 🙂
Another happy owner. Had to do one RMA but the seckond one here is great and went togeather like greased lightning. I was able to put togeather a RAID 0 configuration with 2 Maxtor Dimondmax 9 80 gb SATA drives...no problems (gota love 10 min Windows instals 🙂, but I dont think tey support NCQ either!
Now I agree with the others we need some darn 6800GT to go SLI 😉
3DMarks 3972
Athlon64 3000+ (Winchester) @ 2519 MHZ
Asus A8N-SLI Deluxe @ 280 MHz HTT
CMX512-4400C25 @ 229 Mhz 2 3 3 10 T1
Single 6600 GT @ 594 Core 1255 Memory (76c Max)
This computer was pretty cheap and has huge upgrade potential, I'm happy so far. I would be nice if the A8N would allow my memory to shine with a 1:1 ratio, but 240 is the max for now and I only have a 9x multi to work with so, thats my only complaint.
Side topic:
76c on the core for that card is kinda freaky... Any suggestions?
It's an Antect Truepower 380, which yes is a little low, but it's got 24A on the 12V which is at least ADEQUATE but not ideal. The problems persist in a barebones situation with only an optical drive connected in addition to the required other components (CPU, RAM, Mobo, Video), so it's not very likely it's a power issue as that supply is at least enough to efficiently drive that few components. It is a 20-pin connector, but so far i've still only heard mixed answers between 20 and 24 pin ATX connectors. If I knew reliably that people with 20 pins were having issues and people with 24 pins were having no issues, then I might consider that issue. But since it all follows a pattern (after a sitting cold for like an hour it will boot and stay up for near 20 minutes, then subsequent boots will either fail or stay up for only about a minute max) I have a hard time believing it's a power issue anyways. 🙂 Thanks though!
I am very happy with this baord. 3200+ cpu all running at stock settings right now because I have not had time to play enough. CPU one time easily went to 2.4 ghz on air just with the fsb setting.
SLI DOES NOT WORK WITH PURE DIGITAL DISPLAYS !!!!
SOYLEN GREEN IS PEOPLE !!!
NVIDIA STIFF US !!
Very unhappy !!!! 🙁
Originally posted by: runestone
The only complaint I have is that I keep getting "cpu fan failure" message on boot. I read in another forum this might be because the board does not recognize the slow speed of the Panaflo 120 L fan on the xp120 heatsink. I thought it was because the fan did not support rpm monitoring.
I was getting this message as well since I am watercooling and there is no CPU fan present. I finally solved it by plugging my front case fan to the CPU header and now the mobo is fooled into thinking that there's a fan on the CPU. Guess you could put a different fan to that header, though you will lose the ability to monitor your CPU RPM from the mobo.
Sweet!!! All this worrying and it was one of the easiest builds I've ever done.
ASUS A8N-SLI DELUXE REV 1.02
(1) AMD64 3500+
(1) XFX 6800GT - YES, THE XFX CARD ACTUALLY WORKS GREAT!
(2) 512MB GEIL ULTRA-X 2-2-2-5 DUAL CHANNEL PC3200/DDR400
(2) MAXTOR 120G ATA133 RAID STRIPED (240G)
(1) POWER SUPPLY - ENERMAX SP|485W(P4)EG495P-VE SFMA
(1) BURNER DVDRW AOPEN | DUW1608
(1) CASE ENERMAX|CSX656TA-B
(2) 80MM REAR FANS
(1) DIAL MODEM (BACKUP PLAN)
(1) ATI-TV WONDER PCI
WINDOWS XP SP2
ALL THE SOFTWARE THAT CAME WITH THE A8N-SLI DELUXE MOBO IS INSTALLED
STOCK/BIOS & SPEEDS FOR NOW
LATEST WHQL NVIDIA DRIVERS
3DMARK2005 - 4530, FIRST RUN OUT OF THE GATE!
STABLE AS A ROCK. CAN YOU SEE MY GRIN!!!!!! 🙂)
A friend of mine owns a computer store and has built 3 of these and none have had problems. I have noticed that there a LOT of first time builders in these threads and they will definitely have problems getting machines to run stably.
My mobo sucks got to rma it cause asus some are bad some are good. Of course I am the guy to get the bad mobo lol.... oh well whats 2-3weeks waiting on your 3k investment of time and money?
I love the features and purchased this board expecting a rough road at first. When this much new technology ends up on a board and launches I enjoy working through and trouble shooting the issues. I also expect issues because its all brand new. By far ,aside from resetting the bios to add devices which I hear may be corrected through a bios update at this point, this is the best set of mobos i have ever had the pleasure of working on. I think your assumption that people are complaining may just be people asking for help about frustrating issues. I will say one thing, the long thread gave me a heads up as to what to expect and is full of great information.
These boards rock and will solidfy with time and driver support which asus and nvidia are fairly good at.
(Per machine)
Lian-Li Warrior (Xoxide) Black Aluminum case, blue led lighting (6 fans= 120mm blow hole exhaust top, 2 front 80mm intake, 2 side 80mm intake, 1 rear 80mm exhaust, dual blue cold cathode lights, 2 front usb 2 ports)
Asus A8n SLI Deluxe motherboard
Audigy 2 ZS THX soundcard
2 gig OCZ Platnum Rev 2 low latency 2-2-2-5 DDR 400 ram
Athlon 64 bit Clawhammer processor (FX 55) @2600
2 Geforce 6800 Ultra PCI Express cards Asus 1st machine, EVGA second machine
2 Seagate Sata 2 160 gig hard drives
1 Maxtor Sata 2 250 gig hard drive 16mb Cache
Plextor 16x dvd burner with 4x double layer recording
Samsung 16x DVD ROM ripper
Pc Power and Cooling 510 Turbo deluxe SLI power supply
Gigabyte Rocket 3d Pro CPU fan heat sink
Arctic Silver 5
CPU idle 39C
load 49 C (3 Hours of grinding in EQ2)
Originally posted by: bkzshabbaz
I am not happy, because I cant get my hands on 6800GT's or Ultras, and im stuck with a 6600GT =(
Its like Asus releases such a nice board, but theres no cards to go with it
Mwave, or Zipzoomfly if theres any left Bud 🙂
Monarch computer systems have the 6800 gt's sli for 475.00 each bfg overclocked I got mine from there last week for $440.00 each at the time
Udderly way to expensive. Couldn't resist cw. 🙂
I bought the XFX 6800GT on 1/1/05 at 3am, from ComputerHQ for $489...just after I bought it, they raised to $589!! I guess I got ripped off less than I should have. LOL. But, I probably got the first card in 2005!
newegg had em yesterday for lo $445 I think.
Yes I am still a VERY happy A8N-SLI owner. Love the board.
I'm a thrilled owner as well.
Rig:
A8N-SLI Deluxe
Athlon64 3000+ @ 2.6GHz
1GB PC3200
GeForce 6800GT PCI-E
Empty PCI-E slot begging for another 6800GT
SB Audigy2
I don't mind a rough road at first either. The only thing that slightly bugs me right now is the ongoing 240+FSB 1:1 1T memory timing problem, but I know in due time they will fix that as well.
It seems like a good board although mine is still not running entirely stable. I still keep getting the odd restart here and there. I don't know if it's my overclock not being stable or just the motherboard bios. I am waiting for a solid stable bios, then I can decide.
