I'm not sure how the SL1 work, but my 5D mkII will pick the largest aperture and best ISO in auto ISO in shutter priority mode.Is there a way to shoot Aperture priority, and have a max shutter speed?
I have the SL1, and I just assumed it would do this, but I cannot figure out how.
I want to set the Aperture to something, say f/1.4, and then shutter max to 1/320, and then auto iso.
Can you use manual mode?
Not sure.
How does it work?
Do you guess at all settings, take picture, chimp, revise settings, repeat?
Not sure.
How does it work?
Not sure.
How does it work?
You described manual mode.
Ditto on Manual mode. Nothing wrong with aperture/shutter priority when you must use them, but really, if you want to take control of you exposure and are shooting printable keepers you may want to adjust in post production, learn to use Manual mode and shoot in RAW.
Yes.No... Because manual mode won't adjust shutter speed or ISO.
What I want is a mode that lets you set aperture and shutter speed, and then adjusts ISO accordingly. That would be really useful for shooting portraits in low light. Max aperture + 1/200 shutter + auto ISO
I'm assuming this would be in low light where your ISO has nowhere to go but up? The problem with the mode you want is that if you set the aperture and shutter speed such that ISO would need to be 25 or less, the camera would either not let you take the shot, or it would and you'd end up with a white frame because it's so overexposed.
There is a lot of value in learning the basics of exposure, and the triangle relationship between ISO, Aperture, and Shutter Speed.
Easy for you to say if your camera has 2 or more dials. Us low end folks are stuck with single dials by the manufacturers' product stratification.
Yep. So, how do you enable that? Of course, I CAN use manual, but having this default on the camera makes it easier to catch quick shots that I don't have time to set up manually.to OP: you're describing minimum shutter in Aperture priority mode.
This is a new feature that I've personally used on a Canon 6D.
It only applies to Av mode (and maybe P).
It lets you pick a minimum shutter speed. I keep mine at around 1/125-1/250.
In Av mode, since you set the aperture, the only things left that the camera can manipulate is shutter speed and ISO (if you put it in Auto ISO mode).
Let's say I had 50mm f/1.8 lens, in "ok" lighting.
- In Av Mode, say you set your aperture to f/1.8
- Canon typically sets their 'recommended' shutter speed of 1/focal length, so that means in low/med light, it'll keep aiming for 1/50.
- The camera will auto-adjust the ISO to achieve this 'recommended' shutter.
- Say that to achieve this in your environment, the final values for shutter and ISO were 1/50 and ISO 400.
- with minimum shutter, you'll force the shutter to be 1/250 (if possible).
- you should know that the camera will pump up the ISO as far as it can go (you set the max, say 6400), before it'll start lowering the shutter speed.
- the final values in this test would be something like 1/250 and ISO 2000.
