- May 4, 2002
- 3,345
- 32
- 91
Passing HDMI through my receiver is causing some problems due to Windows detecting the receiver instead of my monitor, so I was curious if there is a setting to pass only audio through the card's HDMI out? This will have to be done outside the receiver since it apparently doesn't support it. My motherboard's onboard is analog only, or I would obviously use that.
Connecting my monitor with DVI and then HDMI from my card to the receiver does not work reliably. 50% of the time it says a cable is unplugged, or my monitor switches to standby and doesn't work until I either turn off the receiver or remove the HDMI cable.
