Is there a way to change a hard drive manufacturers name?
debian0001
464
Hello,
Is there a way to change a hard drive's manufacturers name or model that is detected by the bios?
debian0001
464
I like using the Samsung SSD Data Migrator software but it only works to Samsung SSD drives.
razel
2,337
93
101
This is at your own risk, but assuming you ensure the partitions fit, perhaps you can hot swap the drive just before it begins cloning. Perhaps just before the final click of the dialog button.
Other option is to pay... from what I remember many will sell you the full version at a discount.
debian0001
464
I'm aware of CloneZilla, I just liked how convenient the tool is :(. It was great to do it live.
dd is linux based, I am not sure how easy it is to move from a 500 GB mechanical drive to say a 256 GB SSD drive.
debian0001
464
Thanks, I will see if is possible.
Feb 25, 2011
16,996
1,625
Not easy. I think that EaseUS utility (either "partition master" or "todo-backup") is pretty well-regarded for that though, and it's not a linux-based utility.
You could theoretically do it with DD if you can shrink the partition to <250GB first.
ArisVer
1,345
32
Well, your nickname suggests that you know linux.
As dave pointed out, you must shrink the partition of the first disk (to be copied) to equal or less than the second disk. But the same thing is needed with CloneZilla.
There are other utilities that can do this without the need of shrinking the first disk but I am not sure which ones. I usually shrink the disk and copy the partitions (assuming Windows, the recovery partitions and OS partitions) with the MiniTool Partition Wizard Free.
debian0001
464
Thanks, yeah I know a little Linux :)
I was just more curious if there's a way to spoof it as a Samsung drive or change it so I can use the tool since it was so easy. I have used CloneZilla and recall I had to do the resizing. I think I just made the drive smaller with Windows Disk Manager.
AlienTech
117
Jusr use AOEMI backupper, it will shrink and copy the partition.. and it is free.. It also stores the image compressed.. My boot drive ends up around 23GB from the 70gb partition..
Batmeat
807
45
Hard disk Serial numbers are easy to spoof, but to my knowledge there is no way to spoof the manufacturer name without the manufacturer software they use to code their hard drives.
corkyg
Elite Member | Peripherals
27,370
240
Good point, and I believe it is based on a hash of specific drive components. IOW, it is automated by the OEM, and the hash needs to match reality.
