is there a way to burn files over a network using nero?
MustangSVT
11,554
12
i have the latest nero.
on my computer (xp pro) i have 24x burner (with burnproof) and other computer has 2x burner with win98se.
instead of copying the file over and burning it, is there a way to directly burn a cd over a network?
thanx
neuralfx
1,636
ya i do it quite frequently, when you look for your source, look in your network neighborhood, and choose your files, of course the files have to be on a network share .. besides that its pretty straight forward .. good luck ..
-neural
MustangSVT
11,554
12
that's the problem.. on my sources part (window on right), it only shows my desktop and storage devices on my computer, nothing for network...
maybe i need to enable it somewhere?
ivwshane
33,364
16,742
The only way I was able to do it is by mapping a networked drive in my computer.
gaidin123
962
Depending on your OS, right click on Network Neighborhood, or My Network Places or whatever stupid name MS has decided to call it today, select Map Network Drive, follow the syntax of:
\\computer_name\sharename or \\192.168.x.x\sharename
and hit enter. If all goes well you should get a login prompt. By default on some windows (all?) your C drive will be shared by default c$.
Good luck! It works really well. Nero caches network files and I haven't had a problem...
Gaidin
