BonzaiDuck
The mounting specifications are the same. It is probable that the newer substrate is weaker than the old one, but that just means that the old one exceeded the required strength by a larger amount than the new one. A cooler which was fine on the old processors but damages the new ones is a cooler which was grossly out of spec in the first place.
Somehow, the damage potential involves the tabs on the latchplate which bear down on opposing tabs of the processor cap/IHS. The force from the cooler mounting assembly bears down on the processor cap. And I'm still trying to figure out how putting a tapered shim between the CPU PCB and the latchplate, mating evenly with the lower lip of the processor cap, eliminates some or all of the risk.
ThermalRight says to use theirs; ASUS says to follow their manual and leave the "installation tool" in place. I'm not sure that the tech-reps answering my questions know enough of the particulars to explain it accurately. Especially, I'm more inclined to follow the ASUS recommendations.
Most of the better-performing heatpipe coolers in years since the copper TRUE exceed the spec, some more, some less. I'm inclined to think this is more a matter of a shipping and movement situation than simply installing the cooler and letting it hang on the board in a vertical tower case.
Anyway, this is all going to prove out one way or the other -- when I finally do a final check of electrical connections, plug it in, and fire it up for the first time.
