Originally posted by: Roguestar
:thumbsdown::thumbsdown::thumbsdown::thumbsdown::thumbsdown::thumbsdown:
I don't know what you are smoking, but I hereby demand you provide benchmarks, specifically in Quake 4 seeing as you picked that example, that one person using a Core 2 Duo unoverclocked with DDR2-533 will experience a noticeable difference in framerate that will make an actual difference in the game. I also require you to prove that the difference in memory bandwidth in DDR2-533 and DDR2-800 will cause a significant bottleneck in gaming performance (Quake 4 again, thanks), with all other factors including components and gaming skill being equal. In fact, the only time it would make a difference ever would be if it somehow reduced the playability of the lower speed RAM's PC to beneath a playable framerate whilst the higher speeded RAM maintained a playable game. If there is in fact such a large difference in DDR2-533 and DDR2-800 in a real world situation, limited only to differing RAM speeds then I will conceed that you are correct.
Until that time I and the previous sane posters will maintain that you are infact both wrong and insane, and unaware of what a "noticeable difference" is in such a small factor (compared to CPU/GPU difference), and consider everything that comes out of your mouth on the subject to be FUD.
