Modelworks
- Feb 22, 2007
- 16,240
- 7
- 76
The only other thing I can recommend is to download something like everest ultimate and read the smart values on the drive, see if any are questionable.
Originally posted by: Blain
Fresh drive - Quick format
Used drive - Full format
Full format does not do what people think it does. Full format erases the file table for where the files begin and end, then tries to read each sector. It does not erase the data. Remember that when you share flash drives or hard drives with friends.
The best test I can think of is to download the drive tools from the manufacturer and run their long test or surface scan.
I've got a Kill-a-watt that we were trying to max out. IIRC overloading the CPU made it draw less current because it starved the GPU. Seems like we set affinities or somehow gave the GPU access to more CPU power to really get it cooking.Iometer will work but can be a pain to set up.
For PSU the OCCT PSU tester alongside with Prime95 small FFT gets things going. (Prime alongside seems to get the draw higher when more than 4 threads are required.)
What test do they substitute for real world reliability/lifetime? Do they run it at high temps or something?.....
When they test hard drive MTBF they don't do it by continuous head activity 24/7, but by simulating what a normal use for the drive would be. I could see how running a drive with constant activity might cause failures that otherwise would not occur.
Basically, I want a program that I can use to burn in a new hard disk so I can return it if its bound to break in a month or something
Nothing like replying to a ~4 year old thread!![]()
What if it breaks in two months?
A test like this is pretty counterintuitive, as it only reduces the life of your drive rather than predict the future.
