DamZe
- May 18, 2016
- 188
- 84
- 101
The GTX 1070 is a solid purchase with your hardware and should offer some legroom to spare. I jumped from a 780 to a 1080 and it was a huge leap in performance, I imagine a 960 to a 1070 would be a similar jump. Others may correct me if I'm wrong, but a 480 will likely pump out more heat than the 1070. If you can wait 3-4 months, it can't hurt to see what Vega does to bring down prices/offer competition.
God forbid the average AIB RX480 pumps out one or two degrees Celsius more than the 1070, what on earth does that have to do with anything? They are a good $150-200 apart, so anything you gain in a miniscule temperature increase you more than make up with money saved. If the OP needs a Card for 1080p, a quality AIB RX480 8GB is all that is needed.
Back to the GTX 1070, this card is the modern-day equivalent of a x50Ti product bracket, taking into consideration that the Titan X(P) isn't even a full GP102 chip, which means it would be in your best interest to get the 1070 as close to MRSP as possible. Outside of the US that is nigh impossible, so you have my sympathy. Is it worth the premium over the RX 480 8GB for 1080p to the average Joe, not in a million years. I predict a RX480 8GB will outperform the 1070 in DX12/Vulkan in 1-2 years, for now 1440 and up is the ideal scenario for the 300+ GPU price segment. and where the 1070 can flex it's muscles.
