DivideBYZero
- May 18, 2001
- 24,117
- 2
- 0
Teflon was discovered accidentally as a by product derived from a nerve agent used in chemical warfare.
All organic compounds are carcinogens. As well as all polymers, naturally occurring compounds, etc. You are not even safe with water.
Teflon used to mean PTFE, however, Dupont now uses the Teflon brand as a catch-all for any of their fluoropolymer resins (FEP, PTFE, ETFE, PFA, etc). Most non-stick cookware labeled Teflon is most likely using PFA (perfluoroalkoxy co-polymer)
The coating on non-stick cookware is made from a liquid "paint" which contains PTFE (polytetrafluoroethlyene) fluoropolymer and sometimes other fluoropolymers.
Its too late for me to use google to sound smart. At what temperature does ptfe start to give off dangerous chemicals?
PTFE was accidentally invented by Roy Plunkett of Kinetic Chemicals in 1938. While Plunkett was attempting to make a new CFC refrigerant, the perfluorethylene polymerized in its pressurized storage container, with the iron from the inside of the container acting as a catalyst. Kinetic Chemicals patented it in 1941[1] and registered the Teflon trademark in 1945.[2][3]
PTFE is probably one of the most least reactive resins in existence. It's used for a non stick coating. What's dangerous are the by-products of decomposition of PTFE at high temperatures - in excess of what the grille surfaces should see in normal cooking. This is why its unwise to put PTFE treated parts (like baking pans) in a self cleaning oven! On a clean cycle the oven can exceed 900 degrees Fahrenheit which can cause the release of harmful byproducts of decomposition of PTFE coatings. PTFE stands for polytetrafluroethylene. Teflon is the DuPont trade name.
most least reactive
OK then smarty pants---if it's so "non stick" then what makes it stick to the pan?
To enable the use of fluoropolymers in these applications, their surface must be altered enough to promote bondability without changing their other very desirable characteristics. The active metals are the only chemicals known to react with the fluoropolymers. Sodium is the most commonly used material. It is a safe and environmentally sound process.
The etching process is in fact a chemical reaction between the sodium in the etchant and the fluorine in the polymer. Sodium strips the fluorine from the carbon backbone and promotes its replacement with hydroxyl, carbonyl and carboxyl groups which are the organic species responsible for adhesion.
This reaction takes place to a depth of only a few angstroms leaving the bulk of the polymer unaffected but rendering the surface completely bondable with conventional adhesives. The surface energy is increased to more than 70 dynes/cm2 and is easily verified with a water wettability test.
OK, listen folks. Teflon paranoia is rooted in the 60s and 70s (or a little earlier). Some early uses weren't so nicely manufactured. Some early products tended to shed particles and emit fumes when in use. I don't know the exact history, but there was a bit of a scare back in the day because of these crappy products. As a result, there is a prevailing fear that makes the rounds regularly revolving around teflon degradation while cooking. This is not really a concern anymore since modern applications of teflon are much better than the earliest products.
yes, it's a carcinogen if you ingest it. so, if you have pots and pans that have scratches on them, you could be ingesting teflon and not know it. it flakes off overtime if it's scratched.
solution: new cookware
This seems to conflict with what Rubycon and others have said above, i.e. that it's only the byproducts of heating teflon to very high temperatures that are carcinogenic.
she's probably right. i haven't really looked into it much. all i know is that, last time i checked, which was years ago, when the teflon scrapes off over time and into your food, it's carcinogistic.
Do you have a link to a study that demonstrates this?
I would like to see some studies one way or another, but my gut feeling is that any chemical that is labeled a serious risk for birds and small animals if heated above 300F is something I'd prefer not to have in my stomach in flake form. That includes things other than teflon, but most of those types of pans don't flake off. I suppose this actually may be the opposite of the risk, in that the flakes may be inert and the damage may already be done by heating the pan in the first place.
You know what how about YOU google that!
I thought you just knew everything?!
Chefs don't use non stick pans and don't have problems. Perhaps everyone is doing it wrong in the kitchen!![]()
