Is Sempron 3100+ better performer than A64 2800+
tallman45
1,463
Confused a bit by the numbering scheme
Sempron 3100+ 256kb L2 cache retail cost $121
A64 2800+ 512kb L2 cache retail cost $120
Both run at 1.8ghz
Both 754 socket
cryptonomicon
467
2800 is by small percentages.
you coulda found this out on anand in about 2 mins.
what is confusing you is the "PR RATING"
the pr rating of the sempron follows the AXP rating scheme.
the A64 rating scheme is a different mhz/pr ratio.
tallman45
1,463
Everything I found did indicate the A64 was the better choice. The PR ratings threw me as well as the lower (slight) cost of the 2800+.
Who would but a 3100+ when for the same price an A64 can be had ?
mamisano
2,045
They are the same except:
2800 has double the cache
2800 is 64-bit enabled.
So, for the same price it is an easy answer, the 2800.
