Originally posted by: funboy42
So instead of getting the thermostat replaced for under $100 your going to spend $400 on another fridge?
Im sorry to say but if the compressor goes it goes. There is no half cold half not. The reason the coils were warm in one spot and a block of ice in another is because the system frozen up in that one spot and the defrost timer isnt working. Thats also a sealed system so if you have a leak in the line and all the freon leaks out it jusy wont work at all.
You got taken by the guy that shows up it happends. He was trying to screw you out of a big bill and not replace the part he said was broken but the $15 thermo timer and scam you out of the rest. Im serious. Call another place up. Tell them you feel you were getting scamed. Tell them he pulled the back off and there was ice built up on the coils. It doesnt have to be alot, just enough to restrict the air flow of the fan. Tell them he said that its because it was the compressor was broken and after they stop laughing will tell you what I am telling you. Trust me if your compressor goes its going to be loud and should give you warning before it does for a few days by the thing being loud and vibrating a hell of alot. Plus with it being sort of hot and most likly humid in your home with no air conditioning the coils will freeze up a little easier if the timmer isnt working right but I dont see why you need to throw it away for such a cheap part that needs to be replaced.
All it will take is a few phone calls. Then I would of saved you $300 of which you can forward $100 of it for saving your ass
