Ratman6161
Quick question. I've got a Corsair H55 that's I've been using for a long time...probably at least five years. It started out cooling my I72600k, then a Ryzen 5 1600 and now a Ryzen 7 1700 overclocked to 4.0 Ghz at 1.37 volts. It cools the CPU just fine and even under stress testing, my 1700 nver goes above 68C (not with the stock fan...I've got a pair of corsair SP fans running a low speeds instead)
But...its periodically making a clicking noise which goes on for a while and then stops. Like I said, cooling capabilities don't seem effected. I've seen various people in other threads saying that air bubbles could cause that noise. So, I've ordered myself a new cooler because the noise is too annoying, not because it doesn't cool well.
That will leave me with the still functional but noisy H55 that I could use somewhere else. I have a home server in a location where the noise doesn't matter so if the annoying noise is the only issue that's a good place for it. But I do need it to be reliable. Use it or toss it, that's the question.
Thanks
Thanks
