theevilsharpie
- Nov 2, 2009
- 2,322
- 14
- 81
The maximum set by end users who think they know what the temperature should be, or the actual maximum temperature?
Maximum rated operating temperature per AMD.
I'm glad you were able to fix it, OP. :thumbsup::thumbsup:
Wow, I didn't know AMD had the max temp of these CPUs so low.
62 C is likely Tcase and not what he was measuring at 90
Actually it is the max operating temp of the CPU, not max Tcase.
By limiting the maximum temperature to a lower value such as 62C, AMD accomplishes two things - (1) increases the minimum expected operating lifetime of the CPU, and (2) increases the maximum stable clockspeed of the CPU.
If AMD were to spec the CPU as being able to operate at 72C versus 62C, then the lifetime of the device would be roughly 1/2 that of the chip spec'ed for a max temp of 62C in addition to having a lower stable clockspeed for a given operating voltage (power-consumption rises with temperature, even if clockspeed and voltage remains the same).
No, I saw that, but that's pretty vague. 62 degrees where? It doesn't bother saying.
Here's an example on the intel side:
http://ark.intel.com/products/41447...ocessor-(8M-Cache-2_80-GHz-4_80-GTs-Intel-QPI)
They're pretty open with which temperature metric they're talking about.
