AzN
Banned
- Nov 26, 2001
- 4,112
- 2
- 0
Originally posted by: toyota
Originally posted by: Schmide
Don't take this the wrong way, but I think the use of bottleneck is semantically poor for this type of computing relationship. I know it's the common term, but I think it's a skewed version of it. The CPU may be the limiting factor in terms of maximum FPS; however, it is the video card that would limit the system at the point of minimum FPS. The only time a CPU would truly limit the video card in this relationship is, if it attempted to compute some particle system which by good reason no modern game attempts to do. In bottle necked system one component continuously prevents another component from ever reaching saturation.
sorry but a cpu can and does effect minimum framerates. also you really have things backwards as a faster video card can indeed increase max framerate(to a certain point) even if the cpu is the limiting part of the system.
for example if you had a 2.6 P4 and 8600gt and then replaced it with a 9600gt your min framerate would still be same in many games but your max framerate would go up especially at higher res.
That's not quite right when 8600gt is gpu limited in many of the games out there now.
