Originally posted by: Googer
fewer sticks of higher capcity means lower latency and = better performance
Adding memory to the 3rd slot makes your system run in single channel mode at higher latency
SOMEONE link up some benchmarks for this guy! :laugh:Originally posted by: Blain
>> Benchmarks <<
I want to see benchmarks for different memory configurations under XP and/or 2000! Show Me! :laugh:
Originally posted by: chocoruacal
Run the RAM synch with your FSB. If you're using a 133mhz FSB chip, then running the RAM at 200x2=400mhz isn't going to make any difference; you can fill all three slots and run at 133x2=266mhz.
EDIT: and to answer the title of the thread, no, in certain applications running more RAM could hinder performance.
Hello, Dr. Cools 2nd account!!
You are wrong in that statement however. 100% wrong. As long as you have 2<= then you will runn in Dual Channel. As for higher latency yeah if you put all 4 slots filled you will have to increase the Command Rate to 2T on most M/B. However your statement that smaller memory is faster is utter bullsh!t.
#1. Its just wrong.
#2. THe only thing that DOES apply to is cache which isn't DRAM it is SRAM.
Maybe you should check your information before you post.
-Kevin
#1. Its just wrong.
-Kevin
Thanks Kevin, I knew that but You mis-understood my statement or I was just a little bit incomplete. Adding a third stick to a dual channel config will cause it to operate in single channel mode. I know all about dual channel, it was used long before DDR came around.
No it wont!!! You have no idea what you are talking about.
They have 2 Channels.
Bank 1 = Channel 1 and can hold 1 DIMM. Banks 2 & 3 are on channel 2 and can hold 1 DIMM each =2. They are still on seperate memory channels! Why in the hell do you think they have boards with 3 DIMMS if it is going to run in SC.
You should just stop posting.
-Kevin
You are full of shit. Didn't you read my post?!?! I said
BANK 1 is on Memory Channel 1
BANKS 2 &3 are on memory Channel 2.
Where in that statement did i every say that each was on its on dedicated channel?
Why dont you just stop posting now that i have continually proved you wrong. Or at least just stop posting in this thread.
-Kevin
DAPUNISHER and mechBgon good enough? I had a discussion with both of them about the NF2 and dual-channel memory. Apparently, it is the exception to the rule, and it doesn't require matched pairs of memory in pairs of banks in order to operate in dual-channel. As long as you populate each memory channel with X bytes of RAM of the same organization, then the addresses up to 2X will run in dual-channel, and any further memory will run in single-channel mode. Sounds pretty neat to me.Originally posted by: jvarszegi
As an impartial observer (who also doesn't know who's right), I have to say that neither of you has proved anything. Why don't you point to some online authority? That ought to settle things.
-Kevin
-Kevin
I can confirm that Kevin is indeed correct. He's not exactly being congenial though. Learn some respect dude. You shouldn't have a quote about trolls in your sig if you're going to act like one. :thumbsdown:
P4 dual-channel systems are of course different, and require exact matched pairs, otherwise the system reverts to something Intel calls "virtual single-channel mode", or something like that. So stick in 3 DIMMs, or a non-matched pair of DIMMs, and you'll only get single-channel performance out of the whole thing.
A historical FYI, there have been multi-channel/multi-bank/interleaved memory arrangements before, but I don't think that they were ever specifically called "dual-channel". DEC Alpha workstation boards used to work that way, as did many servers, and I think the Intel 440GX chipset, if you populated all of the memory banks, could do some serious four-way interleaved memory action. Interestingly, even the original Pentium chips were effectively dual-channel, since they required matched pairs of 32-bit SIMMs, to match the 64-bit data bus of the CPU. (And then DIMMs were invented, and were 64/72-bit wide themselves, so no more need for pairs of memory... until DC DDR rolled around again...)
SIMM's were 16bit's each it took Two of them to make a 32bit data path, that was untill Synchronous ram apearead on the market and a single DIMM was 32bits wide It put a temporary end to having to buy memory in pairs. I remember that.original Pentium chips were effectively dual-channel, since they required matched pairs of 32-bit SIMMs
Sorry guys. I guess im arguing over nothing and just randomly insulting, i feel so ashamed 😱 😱 ... i have used my one noob "posting" for the month of December 😛 . At any rate i am sorry, just get your sources and info straight before you post, if you are found to be wrong DONT keep arguing.
Originally posted by: V00D00
Memory only runs at full speed when you have all the slots on your board populated to their maximum. At least that's what I was told.
