Nothinman
- Sep 14, 2001
- 30,672
- 0
- 0
I would've moved to Linux full time if it supported all the fonts that I use. Anyway to get around that?
Put the fonts in your ~/.fonts?
I'd imagine if you bought a preinstalled ubuntu dell laptop, you wouldnt have these problems, but don't expect the install to be super duper smooth in all cases. Thankfully the support forums are excellent and you can usually find the solutions you need, but be prepared to edit config files.
And don't expect your experience to be the norm either, I'd say all of the hassle that you went through for X and compiz are the exception instead of the rule these days.
although there are still plenty of apps I'd like to remove (such as gimp) which I cant do without basically breaking the desktop. It definitely needs to be made a bit more modular.
It's perfectly modular, what you're noticing it wanting to remove when you try to remove the gimp should just be the ubuntu-desktop metapackage which shouldn't break anything.
abiword would work well enough for most of my uses, the fact that it cant open a file over a network share is an absolute deal breaker, not to mention ridiculous beyond my understanding. Some apps can open over a share, some apps cant. Its completely inconsistent.
Some support the Gnome VFS and some don't, it's the same as Windows. I've seen plenty of apps break when given a UNC path on Windows. But if you actually mount the share then everything can access the files just fine.
Sadly though, battery life is about 50% less on ubuntu, even with every power management hack I can find. I dont know why it is, but it just is. That combined with suspend/hibernate issues make it totally inappropriate for a laptop that you actually want to use on battery.
That makes it inappropriate for your laptop on battery, the same isn't true for everyone.
Truthfully, if anything, ubuntu makes me want a mac more than it makes me want ubuntu. A mac has the same prettiness as ubuntu, a solid inclusion of preinstalled apps, the same lack of security issues - but it also comes without the battery life and suspend/hibernate issues, the hardware configuration issues, the network sharing issues, and the ability to use a competent version of microsoft office, allowing me to get actual work done. Unfortunately, it is also quite the opposite of free, being more expensive than any PC.
It also comes without the massive amount of free software, the free updates to a new release every 6 months, the awesome package management, the ability to change the UI theme and IMO the prettiness just isn't there with OS X. I seem to be in the minority but I just find OS X ugly and a PITA to use.
