SDPlissken
drag and SleepWalkerX Thanks.. i have the tforce 6100 on the way.i was not really able to find a definitive answer on if the msi-fid worked with linux. cause of that networking chip that is used on it.
Originally posted by: logicmaster2003
yea Linux is worth running.. but in my case.. I've got 2 computers:
* One is strictly for winXP GAMING which I only turn ON when I want to play Counterstrike, Battlefield1942 and such.
* One is purely for LINUX testing pleasure which is always ON. I use this as my main Internet websurf / chat / online music + ripper (streamtuner) / watching movies.
I also use my winXP GAMING PC as a remote storage for all of my linux "/home" directories.
2) Support for secure wireless is... under development. WEP might work, WPA is in the works. Start with an open configuration and build your way up.
Linux is still not ready for "prime time" but it's getting closer.
You can't assume peripherals like cameras, printers, scanners will work and none of the manufacturers seem to care about Linux driver support.
There is also no such thing as a generic Linux driver. Each distribution is different and this can also drive you nuts.
Good luck playing games, managing your finances or doing taxes on Linux.
My experience with Linux on the desktop is quite different. I feel like I'm always fighting things. Fighting to get some hardware to work. Fighting to get the correct resolution. Fighting to get my mouse buttons to work.
Neither is Windows IMO.
You can't assume that with Windows either, at least not if you want a product that works well. HP multifunction printers are probably the best example. They may work in Windows but you'll have to install a dozen services and you're pretty much guaranteed that the functionality will be intermitten and HP's crap software will cause problems on your machine. And these days most cameras work fine AFAIK, most of them just show up as regular USB storage devices so you can copy the files off like any other USB drive.
Generally if you get hardware that works well in Linux it'll also work well in Windows and probably better than the cheaper crap that doesn't work in Linux.
Technically not true. They basically all use the same drivers, some distros will go some extra steps and include out of tree drivers like rt2500 but that's pretty rare since it can be a lot of work. It's just that you can't copy binary drivers between kernels because of different compilers, kernel config options, etc. It's only a pain when the manufacturer won't release specs for their hardware so that a GPL'd driver can be written.
I do all 3 of those things just fine.
My HP6210 installed flawlessly under WinXP. It help's to read the quick start guide.
OK, you can play games with Linux. I think they have their equivalent of Solitare or Minesweeper. However no avid gamer would conside Linux the best OS platform for games and most leading edge game developers are focused on XP because that's where the $'s are.
Last I checked neither Money, Quicken, Turbotax, or Taxcut had Linux versions.
I've had my issues with Windows but XP really is a pretty good product and in my experience everything is compatable and works well.
ost software developers have profit incentive and its harder to make money off open-source software (that's why NMap had to go closed-source..).
Huh? Looks like the source is still available from insecure.org and is still under the GPL.
linux can't play games!
yes it can!
but no serious gamer will take it seriously!
show me a game that is supposed to be serious!
Really? Because when I plugged my MX-510 into my computer, XP detected all of its buttons just fine. Scroll works, middle-click works, thumb buttons are great for forward and back in the browsers.Originally posted by: Nothinman
I have the same feeling with Windows.
Linux? Basically it's a two-button mouse.
