"BDawg
I disagree, I think *ALL* mp3's sound like crap compared to the original, the difference is huge really. Then again, I listen to stuff out of Event 20/20bas speakers which show every detail with a magnifying glass..."
In february 2000 c't magazin organised a blind listening test. 300 Audiophiles were involved, finalists tested 17 1-min clips from different artists (classic and pop):
original CD recording
128 Kbit/s Joint Stereo [MusicMatch (FhG) v4.4] encoded PC decoded Mac
256 Kbit/s Joint Stereo [MusicMatch (FhG) v4.4] encoded PC decoded Mac
all on cdrs and played in a Recording Studio on:
B&W Nautilus 803, Marantz CD14 with amp PM14 (Straightwire Pro cabling and extra's) [DM30000- so bit more than $15000]
Sennheiser Orpheus Electrostatic Reference-headphones with tweaked accompanying amp (digital and analog out) [>$10000]
Conclusions:
90% of the 128 Kbit material was picked out
MP3@256 was rated to have the same music quality as cd!
If you find MP3@256 to be of inferior quality compared to the original cd, you're probably doing something wrong with the test or you have failing music equipment or ears. Maybe this is something for you. You can always read the article in the german c't 6/2000 on p92.
The treshold of mp3 transparency lies somewhere between 128kbit/s and 256kbit/s, depending on the kind of music and your hearing and equipment.
from
http://www.r3mix.net/ click on quality, i remember some site had the real data, no one picked out the cd over the mp3, it was like 3 would pick the 256mp3 out form the cd, but 3 others would pick hte cd saying it was the mp3 quality.... i'll look for it
