sdifox No Lifer Sep 30, 2005 100,357 17,921 126 Feb 16, 2009 #26 Originally posted by: Aharami I ended up just using wire nuts since wire is hidden behind a couch and I cant tell the difference in sound quality Click to expand... it's good for AC, it's good for speaker wires
CallMeJoe Diamond Member Jul 30, 2004 6,938 5 81 Feb 16, 2009 #27 Originally posted by: sdifox Originally posted by: Aharami I ended up just using wire nuts since wire is hidden behind a couch and I cant tell the difference in sound quality Click to expand... it's good for AC, it's good for speaker wires Click to expand... FWIW, wire nuts work best for solid wires (like Romex). They're not that reliable for stranded conductors.
sdifox No Lifer Sep 30, 2005 100,357 17,921 126 Feb 16, 2009 #28 Originally posted by: CallMeJoe Originally posted by: sdifox Originally posted by: Aharami I ended up just using wire nuts since wire is hidden behind a couch and I cant tell the difference in sound quality Click to expand... it's good for AC, it's good for speaker wires Click to expand... FWIW, wire nuts work best for solid wires (like Romex). They're not that reliable for stranded conductors. Click to expand... Depends on what you did with the wires. If you twisted them on first, then put on the cap, it is fine.
