can you please elaborate on how sunlight will damage computer parts?As long as you don't have it in direct sunlight you're good, just be aware your computer is far more susceptible to damage if not enclosed in a case. A senseless risk in the long run.
Apart from being dishonest in their technical specs (and not even mentioning their crooked past with memory sticks), OCZ has big problems with on the corporate side. Google the article OCZ : The Master of SSD (Shady, Suspect, Deceitful).actually it IS one of the best. Just because a small number of OCZ's MASSIVE client base had trouble does NOT mean its a bad SSD.
Heat. It causes a greenhouse effect, and the temperature increase due to it is anything but insignificant.
how does it cause a greenhouse effect if there's no glass? The heat dissipates quite easily since its an open case. I imagine if it was a closed case (especially black colored case) it'd cause a greenhouse effect.
I have my side panels off, and its a gorgeous sunny day, and it don't see any of my temps going up "significantly".
I'm replying for 2 reasons.
1) To let you know you just revived a 4 year old thread
2) To reclaim the last word
I was going to comment, but you said it for me.A case can provide a sort of "wind tunnel" effect where air is intentionally directed to flow in a specific way to keep your components cooler. Without that wind-tunnel effect, such as without a case at all or a poorly-designed case, you could potentially get higher temperatures than if you had used the case with nice airflow.
So, it's not always true that "no case" will be cooler than a case. Although running with no case might be cooler than a poorly designed case, or a case with such a cluttered nest of wires that it disturbs the flow of air, you can stand to get cooler temperatures by using a case.
Think of the situation with video card coolers that have fans with a shroud. The shroud can actually help temperatures get cooler, because they affect the airflow from the fans. If you take off the shroud (and leave the fans as-is), then you can get worse temperatures because the air doesn't flow as intended.
- I kind of move a lot and i can dissemble and assemble computer parts within 3 mins (yes i can do that in lightening speed). Case make it bulky and difficult to move.
- I want to see my monster while i'm running my rig S=
- easier to troubleshoot on what's going on.
can a curious dust with static chrage miraculously land on my mobo and screw things up?
:thumbsdown:
