Originally posted by: PHiuR
to make the car roll forward? or reverse?
such as putting car in first gear.
then releasing clutch slowly without stepping on gas....
or will this DEFINTILY stall the car?
Will this damage the clutch? Or is it better to put the car in gear, and then coast in neutral when you need to idle along?Originally posted by: Lucky
sure it is, to a point. I do this in heavy traffic all the time, especially in chicago where you only move inch by inch. Just modulate the clutch slightly in, slightly out. Clutch alone will take me to about 4mph, if I let it out past that I stall.
The clutch is a wear item, like brake pads.Originally posted by: jumpr
Originally posted by: Eli
Sure it's possible.
My dad's '83 3/4ton Chevy W/ built 350 will happily idle up the 30 degree or so hill right out of our driveway.
Most cars engines' just don't have enough low end torque to do it.
Originally posted by: teckmaster
if you let the clutch all the way out, you will stall the car.
What are you guys talking about? I do it all the time. I do it for fun, I do it for a little challenge, I do it because I can. I guess I've got the skills, because on level ground, I could do it with any car, even carbureted ones that don't have computer controlled idle speed adjustment.
