YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
- Aug 6, 2001
- 31,205
- 45
- 91
How is it possible though? The Space Shuttle weighs approximately 165,000 lbs empty. How big a parachute would you need to slow it enough to have a cool re-entry? We had parachutes on the capsules we sent up in the 60s but those capsules were tiny compared to the space shuttle and they needed 3 huge chutes to slow those enough to splash down in the ocean and they also needed heat shields to re-enter the Earth's atmosphere from orbit. I think heat resistant tiles is probably the best solution for now.
It's not the space shuttle. It's not the space shuttle. It's not the space shuttle.
This isn't about the best solution for the space shuttle.
This is a theoretical question about whether we could make a space vehicle that could enter the atmosphere and not heat up a lot.
Step 1: Get into orbit with new vehicle
Step 2: Hook up with International space station for refueling and refitting of additional booster rockets
Step 3: Get into the optimal orbit for rapid deceleration and descent
Step 4: Blast the engines and additional booster rockets to slow horizontal velocity and control the descent
Step 5: Once entering the atmosphere, start deploying the series of parachutes designed to slow the descent to augment the slowing effect of the eingines
Step 6: Once altitude is low enough, open larger and larger parachutes to take over for the engines (and jettison the rockets)
I mentioned the SR-71 scenario to show that parachutes are enough to stop a person traveling at mach 3 at 80,000 feet to "re-enter" without the use of any other engines / rockets etc.
Scale that up and you have to get the vehicle to 80,000 feet and traveling at mach 3 and things should be able to meet the requirement for "cool" re-entry (or at lease cooler).
As has been said before, you just need a ton of fuel and you can do it. You could use engines to make the whole descent, or you could use parachutes or some other means to take over once in the atmosphere.
The OP said nothing about practicality or budget. This is an "is it possible" question, and it seems feasible to me. It's a question of how much fuel you can carry to slow yourself down fast enough.
If you can solve that problem with external means, you don't have to carry the solution up from the ground with your vehicle, and you can get rid of the added mass by jettisoning those items. Once you're moving much slower relative to the atmosphere, most of the heat issues of re-entry would be reduces greatly. Since this is not the space shuttle, you could design the thing to have a shape that would work better for slowing itself down for re-entry too.
