I don't think my cpu downclocks without power saving features enabled. I might be living in the past tho 😵
The question is what does that have to do with vdroop? You're saying it's related but have not shown why or how. Vdroop is not downclocking.
AFAIK basic power saving features downclock the speed [f] of the CPU. I hope you understand the basics of speed [f], load, & power draw of a silicon chip (because I'm too lazy & ill-informed to elaborate).
Imagine the power requirements of:
- a downclocked 800Mhz CPU at idle
- an overclocked 4Ghz CPU under load
Now guess how a motherboard & PSU might have problems supplying an order of magnitude more power instantly (results = Vdroop).
I didn't use llc for 4.4Ghz but I did use offset voltage. But the signs were pretty clear: crashes in games that couldn't be helped with increasing vcore, disabled c3/c6 and crashes were gone. I didn't try fixed vcore but it seems to me both situations have downsides so I settled for 4.3GHz.
Temps fluctuate a bit for me as well, but not 10c, more like 5. Check taskman to see what's actually going on. Might be perfectly normal though. What's certainly not good for power consumption is disabling all power saving features. I'm convinced having eist and c1e enabled won't cause any trouble at all.
To dig up old thread & educate the nubs...
Yes it does. My main experience with power saving features is downclocking the cpu while idle. Then if I instantly smash all cores @ high clock rate, it's the Vdroop which messes with my chi (it would be fine @ same settings without f & load changes).
To say Vdroop has nothing to do with it is silly.
at the end of the day sandy bridge is super power efficient, so even it its overclocked to 4.4ghz on 1.35 24/7 when its idle it can't be drawing THAT much power?
Great, nub education is always good.
Turn off powersave features. Use fixed vcore. Experience same vdroop...
As mentioned, that's exactly what the mobo is designed to do. vdrrop isn't limited to low load situations, in fact, it ONLY happens during load. The lower voltage levels at lower loads/speeds is not vdroop. Vdroop is a physical phenomenon. Its a combination of voltage, current and resistance that cause it. The voltage drops you're talking about are related to speedstep NOT vdroop.
You have successfully proven Vdroop is not solely confined to downclocking situations :thumbsup:
No, I have proven that powersaving features and vdroop have nothing to do with each other, because you will see exactly the same vdroop with powersaving features enabled or not. Which is what I said in the first place, but you said that was 'silly'.
As for your cpu being unstable, what I think you actually mean is when using dynamic instead of fixed vcore. I myself experience nothing like that, dynamic vcore is just as stable as fixed vcore in my case. Maybe I should go beyond 4.6GHz to notice something similar, but I doubt it.
You haven't proven anything. Watching the readout of some program is only very loosley related to what is going on in your motherboard/cpu. If you think there is no power difference between a downclocked cpu & stock/overclocked (at idle) then I'll stand by my "silly" claim.
I set all my voltages manually.
I'll leave this convo with this: Vdroop is related to the differential of power draw by the CPU (idle vs load). A higher overclock increases the power requirements (& hence the V differential), a downclocked CPU reduces the power draw (hence also increases the V differential). So power saving features effect overclocking/stability potential.
I gave a scenario where supplied voltage is compromised because of power saving features, & where it may be the straw that broke the camels back, I have seen the results myself (i.e. a CPU fails with power saving features downclocking where it might not otherwise). I didn't say Vdroop was limited to downclocking, & I agree it's a physical phenomenon (moot point; are your really suprised with a physical situation?).
