Question Is it possible that my CPU is giving a false temperature reading?
JBrasch
Replaced a CPU fan on an HP Pavilion g7-2325dx and the whole install went smoothly, I even cleaned off the CPU and the heatsink with an alcohol pad and applied some new Arctic Silver MX-4 thermal paste. Everything is running just fine and showing no signs of system issues other than it being an older laptop. But just to make sure everything was running good I opened up Speccy by Piriform and it showed the CPU temperature at a staggering 255 °F (124 °C) and idles around 212 °F (100 °C). I'm reaching out to you guys because I want to make sure there's nothing wrong and if there is, fix it before any permanent damage is done. The CPU is an AMD A8-4500M. Please help me out here, thank you!
Gt403cyl
51
Generally Speccy is not known for accurate temp readings, try other software and see if the readings are normal, 124c would realistically shut down so it's more than likely a very false reading.
JBrasch
I downloaded HWinfo as well and it appears to give a different temperature reading for the CPU (in the red rectangle) but it does still display the ridiculous temps (in the blue rectangle):
Gt403cyl
51
But it says current is 216f, not right
True, but if it was really running that hot it would thermal shutdown I would think.
That said unless the cooler is not actually contacting the CPU then I don't see how it would still be running that hot without shutting down.
JBrasch
That's exactly why I'm stumped haha
VirtualLarry
56,587
10,227
If that were an AM3/AM3+ platform, with an FX CPU, I would say that the mobo is intentionally setting the CPU temp reading too high, to intentionally throttle the CPU clocks. This happens, when the BIOS (in SMM mode), detects that the VRMs are overheating.
