This necro reminds me that my new UPS has an ethernet surge protector.
Little to no relationship exists between words protect
or and protect
ion. Any protector that would 'block' or 'absorb' a surge is bogus. Especially true of adjacent power strips or that UPS. Those only claim to protect from surges that are routinely converted by your computer's PSU into rock stable, low voltage DC to safely power semiconductors. Those near zero surges, that do not damage appliances, may also destroy near zero protection inside a power strip or UPS.
Making it near zero (and the resulting protector failure) gets to the naive to recommend and buy more potential house fires.
The fewer and informed know (for example) that a properly installed coaxial cable has best protection installed for free by a TV and internet provider. Best protection is a hardwire from that cable, connected low impedance (ie less than 3 meters), to single point earth ground. Then no surge current is anywhere inside. Then no surge current is on any ethernet cable. Then superior protection already inside every appliance is not overwhelmed.
Same protect
ion must exist on every wire inside every incoming cable. Telephone and AC electric cannot connect directly to earth. So a 'whole house' protect
or does what a direct connection to earth does better.
No protect
or does protect
ion. An effective solution connects low impedance (ie less than 3 meters) to single point earth ground. Protect
ion is always about where hundreds of thousands of joules dissipate harmlessly. Either that energy hunts for and dissipates destructively inside some household appliances. Or that energy is never inside; dissipates harmlessly in earth. Only a homeowner makes that decision.
One can foolishly spend tens or 100 times more money for magic box protectors (ie power strip or UPS) with numbers that do not even claim effective protection. Or one can spend maybe $1 per protected appliance for a best and only solution always found where even direct lightning strikes cause no damage.
A protect
or is only as effective as its earth ground. Protector adjacent to an appliance has no earth ground AND will not discuss it. Effective protect
or always has a low impedance (ie hardwire has no sharp bends) connection to what is the protect
ion: single point earth ground. Then no surge is anywhere inside. Then everything is protected. A protector is only as effective as its earth ground. So that even direct lightning strikes cause no damage.
